->Quadro RTX6000
• DeepStream Version
->DeepStream 6.0.1
• TensorRT Version
->TensorRT 8.0.1
->510.47.03
->questions
Running sample graph reference app test1 according to Deploy Graph section in the below URL fails on x86_64
https://docs.nvidia.com/metropolis/deepstream/dev-guide/graphtools-docs/docs/text/GraphComposer_app_Workflow.html#deploy-graph
The errors on console in Graph Composer UI:
2022-05-09 00:49:37 [Error] [carb.python] [./registry/backend/model.py:398] Do not have permissions to save the graph /opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-test1/deepstream-test1.yaml
2022-05-09 00:49:37 [Error] [carb.python] [/tmp/.tmpNvXgRaphComposer/run/composer/omni.exp.graph.composer/omni/exp/graph/composer/run_graph_window.py:252] Saving Graph /opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-test1/deepstream-test1.yaml failed!
However, when I follow the Execute Graph using command-line (execute_graph.sh script), it works on x86_64 with the command:
/opt/nvidia/graph-composer/execute_graph.sh deepstream-test1.yaml parameters.yaml -d …/common/target_x86_64.yaml
How can I work the reference app on the Graph Composer UI?
thanks
