ifconfig eth2 mtu 2022
Is it possible to change the jumbo frame size of the NIC by setting as above?
- INFO
NIC: connect x-5
OS: centOS 7.2
NIC: connect x-5
OS: centOS 7.2
Hello HC,
Thank you for posting your question on the NVIDIA/Mellanox Community.
Our adapters support jumbo frames, so yes you can set the MTU size based on the ‘ifconfig’ syntax you have provided.
As ‘ifconfig’ is deprecated, you can also use:
Example output:
3: eno2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 2022 qdisc mq state DOWN mode DEFAULT qlen 1000
link/ether 0c:c4:7a:32:01:3d brd ff:ff:ff:ff:ff:ff
Thank you,
~NVIDIA/Mellanox Support
