I use Jetson Nano [developer kit version] eMMC module,BSP version:R32.7.4.
Cable connections to SPI1 are as follows:
IRQ ------ PIN12 (I2S_4_SCLK/GPIO79)
RST ------ PIN11 (UART_2_RTS/GPIO50)
SPI_1_SCK ------ PIN23(SPI_1_SCK/GPIO18)
SPI_1_MISO ------ PIN21 (SPI_1_MISO/GPIO17)
SPI_1_MOSI ------ PIN19 (SPI_1_MOSI/GPIO16)
My configuration is as follows:
spi@7000d600 {
status = "okay";
spi@0 {
status = "okay";
compatible = "wkmic,wk2xxx_spi";
reg = <0x0>;
spi-max-frequency = <10000000>;
reset_gpio=<&gpio TEGRA_GPIO(G, 2) GPIO_ACTIVE_HIGH>;
irq_gpio=<&gpio TEGRA_GPIO(J, 7) IRQ_TYPE_LEVEL_LOW>;
But the 40pin spi1 in the dtsi file is:
hdr40_spi2: spi@7000d600 { /* SPI 2 to 40 pin header */
status = "okay";
spi@0 {
compatible = "tegra-spidev";
reg = <0x0>;
spi-max-frequency = <33000000>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <6>;
spi@1 {
reg = <0x1>;
controller-data {
Question 1: Is 7000d600 SPI1 or SPI2 ???
Question 2: Whether the spider needs to be removed???
tegra210-porg-p3448-common.txt (22.0 KB)
Question 3: Why can’t I read and write the register? Is SPI not used normally?
insmod_log.txt (58.2 KB)
