How to add custome base materials
when using Create to add a new material, Ive different base materials to select (OmniPBR for example)... Ive create an own base material based on OmniPBR (because I needed a separate UV-index for the detailnormal).
How can I add my own custom base materials to create? (creating new materials based on my own base materials from the menu).
Carl
Hello @c.bickmeier!
I’ve alerted the devs about your question.
In the meantime, here is some documentation on creating materials in Omniverse: Omniverse MDL Materials — Omniverse Materials and Rendering documentation
You can put the MDL in the MDL\Base folder and the menu will pick it up
Mine looks like this, where the apps are installed
D:\Omniverse\create-2021.3.4-rc.3\kit\mdl\core\Base
