To fix green image save by nvds_obj_enc_process I found the solution at adding nvvideoconvert it word for deepstream-image-meta-test so:
How to apply it to deepstream_test5_app ?
• Hardware Platform Jetson NX • DeepStream Version 5.1 • JetPack Version 4.4 • How to reproduce the issue ?
Hey, have you checked the patch in that comment I need to send the image with bbox and other metadata to the custom server - #28 by Amycao?
hello, yes, i was check this path. this path work for deepstream-image-meta-test, but with deepstream-trainsfer-learning-app how can apply it ?
I think you need to refer deepstream_app.c → create_pipeline for how to add the nvvideoconvert to the pipeline, currently you cannot add that in the pipeline through the config file.
