How to benchmark on Thor to get the real FP4/FP8 performance TFOPS
As the topic described, anyone know how to benchmark on Thor to get the real FP4/FP8 performance? I try to compile Nvidia cutlass and run the profiler but got nothing output. Here are my procedures:
git clone -b v4.3.1 https://github.com/NVIDIA/cutlass.git
cd cutlass
mkdir build && cd build
cmake .. -DCMAKE_CUDA_ARCHITECTURES="110" -DCUTLASS_NVCC_ARCHS="110"
make cutlass_profiler -j
Then I run cutlass_profiler to do the benchmark as below:
./tools/profiler/cutlass_profiler --operation=Gemm --A=f4:row --B=f4:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
./tools/profiler/cutlass_profiler --operation=Gemm --A=e2m1:row --B=e2m1:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
./tools/profiler/cutlass_profiler --operation=Gemm --A=f8:row --B=f8:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
./tools/profiler/cutlass_profiler --operation=Gemm --A=e4m3:row --B=e4m3:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
But got nothing output meanwhile no error.
When I try f16 or f32, the command is
./tools/profiler/cutlass_profiler --operation=Gemm --A=f16:row --B=f16:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
I can get the result as below
CSV Results:
Problem,Provider,OperationKind,Operation,Disposition,Status,gemm_kind,m,n,k,A,B,C,D,alpha,beta,split_k_mode,split_k_slices,batch_count,raster_order,runtime_input_datatype_a,runtime_input_datatype_b,use_pdl,enable_sm90_mixed_dtype_shuffle_test,swizzle_size,op_class,accum,cta_m,cta_n,cta_k,cluster_m,cluster_n,cluster_k,cluster_m_fallback,cluster_n_fallback,cluster_k_fallback,stages,warps_m,warps_n,warps_k,inst_m,inst_n,inst_k,min_cc,max_cc,Bytes,Flops,Flops/Byte,Runtime,GB/s,GFLOPs
1,CUTLASS,gemm,cutlass_tensorop_f16_s16816gemm_f16_256x128_32x3_tn_align8,passed,success,universal,1024,1024,1024,f16:row,f16:column,f16:column,f16:column,1,0,serial,1,1,along_m,invalid,invalid,false,false,1,tensorop,f32,256,128,32,1,1,1,1,1,1,3,4,2,1,16,8,16,80,1024,6291456,2149580800,341,0.0397382,147.449,54093.5
1,CUTLASS,gemm,cutlass_tensorop_h16816gemm_256x128_32x3_tn_align8,passed,success,universal,1024,1024,1024,f16:row,f16:column,f16:column,f16:column,1,0,serial,1,1,along_n,invalid,invalid,false,false,8,tensorop,f16,256,128,32,1,1,1,1,1,1,3,4,2,1,16,8,16,80,1024,6291456,2149580800,341,0.0406298,144.214,52906.6
1,CUTLASS,gemm,cutlass_tensorop_s16816gemm_f16_256x128_32x3_tn_align8,passed,success,universal,1024,1024,1024,f16:row,f16:column,f32:column,f32:column,1,0,serial,1,1,along_m,invalid,invalid,false,false,8,tensorop,f32,256,128,32,1,1,1,1,1,1,3,4,2,1,16,8,16,80,1024,8388608,2149580800,256,0.0484224,161.341,44392.3
1,CUTLASS,gemm,cutlass_tensorop_h1688gemm_256x128_32x2_tn_align8,passed,success,universal,1024,1024,1024,f16:row,f16:column,f16:column,f16:column,1,0,serial,1,1,along_m,invalid,invalid,false,false,8,tensorop,f16,256,128,32,1,1,1,1,1,1,2,4,2,1,16,8,8,75,1024,6291456,2149580800,341,0.0609462,96.1401,35270.1
1,CUTLASS,gemm,cutlass_tensorop_f16_s1688gemm_f16_256x128_32x2_tn_align8,passed,success,universal,1024,1024,1024,f16:row,f16:column,f16:column,f16:column,1,0,serial,1,1,along_n,invalid,invalid,false,false,8,tensorop,f32,256,128,32,1,1,1,1,1,1,2,4,2,1,16,8,8,75,1024,6291456,2149580800,341,0.0610381,95.9954,35217
1,CUTLASS,gemm,cutlass_tensorop_s1688gemm_f16_256x128_32x2_tn_align8,passed,success,universal,1024,1024,1024,f16:row,f16:column,f32:column,f32:column,1,0,serial,1,1,along_m,invalid,invalid,false,false,8,tensorop,f32,256,128,32,1,1,1,1,1,1,2,4,2,1,16,8,8,75,1024,8388608,2149580800,256,0.0707862,110.367,30367.2
1,CUTLASS,gemm,cutlass_simt_hgemm_256x128_8x2_tn_align1,passed,success,universal,1024,1024,1024,f16:row,f16:column,f16:column,f16:column,1,0,serial,1,1,along_n,invalid,invalid,false,false,8,simt,f16,256,128,8,1,1,1,1,1,1,2,4,2,1,1,1,1,50,1024,6291456,2149580800,341,0.147884,39.6215,14535.6
So why FP4/FP8 not available with cutlass_profiler, is that something wrong with my compile or benchmark arguments?
Please check the steps shared in the link below:
THanks.
It is weird. I have followed the steps. But still nothing output when measuring TOPS of FP4.
I am using cuda 13.0.
Have you rebuilt the library? Could you share your steps with us so we can check them further?
Yes I have rebuilt cutlass. I can post my testing steps here.
cd cutlass
cmake .. -DCUTLASS_NVCC_ARCHS="110a" -DCUTLASS_LIBRARY_KERNELS=all  -DCUTLASS_UNITY_BUILD_ENABLED=ON
make cutlass_profiler -j12
./tools/profiler/cutlass_profiler --operation=SparseGemm --m=4096 --n=8192 --k=8192 --A=f4:row --B=f4:column --C=f16:column --D=fe5m2:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
./tools/profiler/cutlass_profiler --operation=Gemm --m=4096 --n=8192 --k=8192 --A=f4:row --B=f4:column --C=f16:column --D=fe5m2:column --enable-best-kernel-for-fixed-shape --sort-results-flops-per-sec
./tools/profiler/cutlass_profiler   --m=4096 --n=8192 --k=8192   --verification-enabled=false   --kernels="cutlass3x_sm100_bstensorop_*"  --enable-kernel-performance-search --sort-results-flops-per-sec --enable-best-kernel-for-fixed-shape
Nothing output when I run cutlass_profiler for FP4.
Thanks for sharing the steps.
We are testing this issue with your commands (it takes some time to compile the cutlass library).
Will update with more information later.
Any update about the test?
It looks like you can get the FP4 results already?
No, nothing output when I run cutlass_profiler for FP4 TOPS. It’s someone else. I follow the steps but still got no output.
We are checking this internally.
Will get back to you later.
Sorry for the late update.
We have confirmed that the F4/F8 benchmark is working with cutlass_profiler.
Please find the details below:
Setup
$ git clone https://github.com/NVIDIA/cutlass.git
$ cd cutlass/
$ git checkout v4.4.1
$ mkdir build
$ cd build/
$ export CUDACXX=/usr/local/cuda-13.0/bin/nvcc
$ cmake .. -DCUTLASS_NVCC_ARCHS="110a" -DCMAKE_CUDA_ARCHITECTURES="110a" -DCUTLASS_ENABLE_CUBLAS=true
$ make -j$(nproc)
F8 Kernel
./tools/profiler/cutlass_profiler --kernels="cutlass3x_sm100_tensorop_gemm_f8_f8_*" --enable-best-kernel-for-fixed-shape --m=9568 --n=1280 --k=3420 --sort-results-flops-per-sec
  Problem ID: 1
        Provider: CUTLASS
   OperationKind: gemm
       Operation: cutlass3x_sm100_tensorop_gemm_f8_f8_f32_void_e5m2_128x256x128_2x1x1_0_ntt_align16_1sm
          Status: Success
    Verification: ON
     Disposition: Not verified
reference_device: Not run
          cuBLAS: Not run
           cuDNN: Not run
       Arguments: --gemm_kind=universal --m=9568 --n=1280 --k=3420 --A=f8:column --B=f8:row --C=void:row --D=fe5m2:row  \
                  --alpha=1 --beta=0 --split_k_mode=serial --split_k_slices=1 --batch_count=1 --raster_order=along_n  \
                  --runtime_input_datatype_a=invalid --runtime_input_datatype_b=invalid --use_pdl=false --enable_sm90_mixed_dtype_shuffle_test=false  \
                  --swizzle_size=2 --op_class=tensorop --accum=f32 --cta_m=128 --cta_n=256 --cta_k=128 --cluster_m=2  \
                  --cluster_n=1 --cluster_k=1 --cluster_m_fallback=1 --cluster_n_fallback=1 --cluster_k_fallback=1 --stages=4  \
                  --warps_m=4 --warps_n=1 --warps_k=1 --inst_m=128 --inst_n=256 --inst_k=32 --min_cc=100 --max_cc=110  \
           Bytes: 37100160  bytes
           FLOPs: 83794247680  flops
           FLOPs/Byte: 2258
         Runtime: 0.290212  ms
          Memory: 119.059 GiB/s
            Math: 288735 GFLOP/s
F4 Kernel
$ tools/profiler/cutlass_profiler --kernels="cutlass3x_sm100_tensorop_gemm_f4_f4_*" --enable-best-kernel-for-fixed-shape --m=4096 --n=4096 --k=4096 --sort-results-flops-per-sec
  Problem ID: 1
        Provider: CUTLASS
   OperationKind: gemm
       Operation: cutlass3x_sm100_tensorop_gemm_f4_f4_f32_void_e5m2_256x256x128_0x0x1_0_tnt_align128_2sm
          Status: Success
    Verification: ON
          cuBLAS: Not run
           cuDNN: Not run
       Arguments: --gemm_kind=universal --m=4096 --n=4096 --k=4096 --A=f4:row --B=f4:column --C=void:row --D=fe5m2:row  \
                  --swizzle_size=2 --op_class=tensorop --accum=f32 --cta_m=256 --cta_n=256 --cta_k=128 --cluster_m=8  \
                  --cluster_n=2 --cluster_k=1 --cluster_m_fallback=2 --cluster_n_fallback=1 --cluster_k_fallback=1 --stages=6  \
                  --warps_m=4 --warps_n=1 --warps_k=1 --inst_m=256 --inst_n=256 --inst_k=32 --min_cc=100 --max_cc=110  \
           Bytes: 16777216  bytes
           FLOPs: 137472507904  flops
           FLOPs/Byte: 8194
         Runtime: 0.333727  ms
          Memory: 46.8197 GiB/s
            Math: 411931 GFLOP/s
