We have combine 4 to 1 frame, but there is on data get only black screen,
we use
gst-launch-1.0 -v v4l2src device=“/dev/video0” ! “video/x-raw,width=720,height=240, format=(string)I420” ! nvvidconv ! “video/x-raw(memory:NVMM)” ! nvoverlaysink
Is there anything wrong?
log:
ubuntu@tegra-ubuntu:~/v4l2$ ./capture.sh
Setting pipeline to PAUSED …
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4[ 797.606405] tegra_channel_capture_frame: entry!!!
[ 797.613819] tegra_channel_enable_stream: entry!!!
l2Src:v4l2src0.GstPad:src: caps [ 797.618729] isl79987_s_stream++
= “video[ 797.624467] isl79987_s_stream–
/x-raw,\ format=(string)I420,\ width=(int[ 797.629678] tegra_channel_enable_stream: exit 0 !!!
[ 797.637325] vi2_channel_capture_frame: entry!!!
[ 797.641846] vi2_channel_capture_frame: valid_ports 1!!!
[ 797.647070] vi2_channel_capture_frame: bypass 0!!!
[ 797.651859] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
[ 797.659249] vi2_channel_error_status: entry
[ 797.663691] vi2_channel_error_status: exit
[ 797.668048] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
[ 797.674044] tegra_channel_capture_frame: entry!!!
[ 797.678747] vi2_channel_capture_frame: entry!!!
[ 797.683266] vi2_channel_capture_frame: valid_ports 1!!!
[ 797.688490] vi2_channel_capture_frame: bypass 0!!!
[ 797.693275] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
[ 797.700665] vi2_channel_error_status: entry
[ 797.705113] vi2_channel_error_status: exit
[ 797.709462] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
[ 797.715464] tegra_channel_capture_frame: entry!!!
[ 797.720162] vi2_channel_capture_frame: entry!!!
)720,\ height[ 797.724690] vi2_channel_capture_frame: valid_ports 1!!!
=(int)[ 797.731281] vi2_channel_capture_frame: bypass 0!!!
240,\ pixel-aspect-rati[ 797.736758] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
o=(fraction)1[ 797.746208] vi2_channel_error_status: entry
/1,\ interlace-[ 797.752017] vi2_channel_error_status: exit
mode=(string)progress[ 797.757753] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
ive,\ colorimetry=(st[ 797.765819] tegra_channel_capture_frame: entry!!!
ring)2:[ 797.772576] vi2_channel_capture_frame: entry!!!
4:7:1,\ framerate=(fr[ 797.777791] vi2_channel_capture_frame: valid_ports 1!!!
action)[ 797.781485] nvmap_alloc_handle: PID 1834: gst-launch-1.0: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Plase pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
30/1”
/GstPipeline:pipeline0/Gs[ 797.805458] vi2_channel_capture_frame: bypass 0!!!
[ 797.812994] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
[ 797.820393] vi2_channel_error_status: entry
[ 797.824845] vi2_channel_error_status: exit
[ 797.829194] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
[ 797.835203] tegra_channel_capture_frame: entry!!!
[ 797.839900] vi2_channel_capture_frame: entry!!!
[ 797.844419] vi2_channel_capture_frame: valid_ports 1!!!
[ 797.849643] vi2_channel_capture_frame: bypass 0!!!
tCapsFil[ 797.854428] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
ter:capsfilter0.GstPad:s[ 797.862508] vi2_channel_error_status: entry
rc: caps = “video/x-raw[ 797.869019] vi2_channel_error_status: exit
,\ format=(string)I42[ 797.875439] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
0,\ wid[ 797.883492] tegra_channel_capture_frame: entry!!!
th=(int)720,\ height[ 797.888884] vi2_channel_capture_frame: entry!!!
=(int)240,\ pixel-as[ 797.895476] vi2_channel_capture_frame: valid_ports 1!!!
pect-rat[ 797.902754] vi2_channel_capture_frame: bypass 0!!!
io=(fraction)1/1,\ i[ 797.908235] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
nterlace-mode=(string[ 797.917685] vi2_channel_error_status: entry
)progressive,\ [ 797.924188] vi2_channel_error_status: exit
colorimetry=(string)2[ 797.929921] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
:4:7:1,\ framerate=(fraction)30/1”
[ 797.938229] tegra_channel_capture_frame: entry!!!
[ 797.946151] vi2_channel_capture_frame: entry!!!
[ 797.950673] vi2_channel_capture_frame: valid_ports 1!!!
[ 797.955897] vi2_channel_capture_frame: bypass 0!!!
[ 797.960685] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
[ 797.968075] vi2_channel_error_status: entry
[ 797.972516] vi2_channel_error_status: exit
[ 797.976874] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
[ 797.982871] tegra_channel_capture_frame: entry!!!
[ 797.987573] vi2_channel_capture_frame: entry!!!
[ 797.992095] vi2_channel_capture_frame: valid_ports 1!!!
[ 797.997317] vi2_channel_capture_frame: bypass 0!!!
/GstPipe[ 798.002100] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
line:pipeline0/Gstnvvcon[ 798.010182] vi2_channel_error_status: entry
v:nvvconv0.GstPad:src: c[ 798.016690] vi2_channel_error_status: exit
aps = “video/x-r[ 798.023098] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
aw(memory:NVMM),\ wid[ 798.030480] tegra_channel_capture_frame: entry!!!
th=(int)720,\ height[ 798.037247] vi2_channel_capture_frame: entry!!!
=(int[ 798.043830] vi2_channel_capture_frame: valid_ports 1!!!
)240,\ pixel-aspect-rat[ 798.049741] vi2_channel_capture_frame: bypass 0!!!
io=(fraction)1/1,\ i[ 798.056596] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
nterlace-mode=(string[ 798.066046] vi2_channel_error_status: entry
)progressive,\ [ 798.072548] vi2_channel_error_status: exit
framerate=(fraction)3[ 798.078283] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
0/1,\ format=(string)I420”
/GstPipe[ 798.086654] tegra_channel_capture_frame: entry!!!
[ 798.094497] vi2_channel_capture_frame: entry!!!
[ 798.099032] vi2_channel_capture_frame: valid_ports 1!!!
line:pip[ 798.104252] vi2_channel_capture_frame: bypass 0!!!
eline0/GstCapsFilter:capsfilter1[ 798.109740] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
.GstPad:[ 798.119904] vi2_channel_error_status: entry
src: caps = “video/x-raw(memory[ 798.125043] vi2_channel_error_status: exit
[ 798.132144] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
:NVMM),\ width=(int[ 798.138151] tegra_channel_capture_frame: entry!!!
)720,\ height=(int)2[ 798.144918] vi2_channel_capture_frame: entry!!!
40,\ pi[ 798.151502] vi2_channel_capture_frame: valid_ports 1!!!
xel-aspect-ratio=(frac[ 798.157410] vi2_channel_capture_frame: bypass 0!!!
tion)1/1,\ int[ 798.164258] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
erlace-mode=(string)p[ 798.173024] vi2_channel_error_status: entry
rogressive,\ framerate[ 798.179535] vi2_channel_error_status: exit
=(fraction)30/1,\ for[ 798.185952] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
mat=(string)I420”
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = “video/x-raw(memory:NVMM),\ width=(int)720,\ height=(int)240,\ pixel-aspect-ratio=(fraction)1[ 798.211167] tegra_channel_capture_frame: entry!!!
/1,\ interlace-mode=(string)[ 798.218864] vi2_channel_capture_frame: entry!!!
progress[ 798.226133] vi2_channel_capture_frame: valid_ports 1!!!
ive,\ f[ 798.232035] vi2_channel_capture_frame: bypass 0!!!
ramerate=(fraction)30/1,\ fo[ 798.237561] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
rmat=(string)[ 798.247690] vi2_channel_error_status: entry
I420”
/GstPipel[ 798.253505] vi2_channel_error_status: exit
ine:pipeline0/GstCapsFilter:caps[ 798.259269] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
filter1.GstPad:sink: caps = “vid[ 798.268024] tegra_channel_capture_frame: entry!!!
eo/x-raw(memory:NVMM),\ width[ 798.275486] vi2_channel_capture_frame: entry!!!
=(int[ 798.282744] vi2_channel_capture_frame: valid_ports 1!!!
)720,\ height=(int)240,\ pi[ 798.288698] vi2_channel_capture_frame: bypass 0!!!
xel-aspect-ratio[ 798.296237] vi2_channel_capture_frame: exit,timeout 20 chan->capture_state 1!!!
=(fraction)1/1,\ interlace-m[ 798.305026] vi2_channel_error_status: entry
[ 798.312198] vi2_channel_error_status: exit
ode=(string)p[ 798.316587] tegra_channel_capture_frame: exit,pg_mode 0 err 0!!!
rogressi[ 798.323957] tegra_channel_capture_frame: entry!!!
ve,\ framerate=(fraction)30/[ 798.329376] vi2_channel_capture_frame: entry!!!
1,\ for[ 798.336655] vi2_channel_capture_frame: valid_ports 1!!!
mat=(s[ 798.342560] vi2_channel_capture_frame: bypass 0!!!
tring)I420”
ubuntu@tegra-ubuntu:~$ v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output-0, isl79987_mipi 1-00
Bus info : platform:vi:0
Driver version: 3.10.96
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 724/240
Pixel Format : ‘UYVY’
Field : None
Bytes per Line : 1472
Size Image : 353280
Colorspace : SMPTE 170M
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Flags :
Camera Controls
hdr_enable (intmenu): min=0 max=1 default=0 value=0
bypass_mode (intmenu): min=0 max=1 default=0 value=0
gain (int) : min=0 max=128 step=1 default=0 value=0 flags=slider
v4l2-compliance -d /dev/video0
v4l2-compliance SHA : a710e1bb7c6803a9347d3899b9129d887221985f
Driver Info:
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 3
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1162): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
fail: v4l2-test-formats.cpp(666): Video Capture is valid, but no TRY_FMT was implemented
test VIDIOC_TRY_FMT: FAIL
warn: v4l2-test-formats.cpp(977): S_FMT cannot handle an invalid pixelformat.
warn: v4l2-test-formats.cpp(978): This may or may not be a problem. For more information see:
warn: v4l2-test-formats.cpp(979): http://www.mail-archive.com/linux-media@vger.kernel.org/msg56550.html
fail: v4l2-test-formats.cpp(991): S_FMT cannot handle an invalid format
test VIDIOC_S_FMT: FAIL
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
fail: v4l2-test-formats.cpp(1553): doioctl(node, VIDIOC_S_FMT, &fmt)
fail: v4l2-test-formats.cpp(1650): doioctl(node, VIDIOC_S_FMT, &fmt)
test Scaling: FAIL
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 43, Succeeded: 39, Failed: 4, Warnings: 3
