Hi all,
as in the title, I can’t change the curve width from the parameters menu as it is greyed out.
I am also getting a console error.
btw I just updated to 2023.2.1
Hi all,
Let me check and get back to you
thank you Richard!
If you go into the “EDIT Control Vertices” mode of the curve and actually select the vertices you can edit the width. The global override does not work there. If you want 1 value to rule them all you can change width interpolation to constant
and changing width on one CV will change the entire curve. See video
Thank you Richard!
