Im new to onmiverse development I want to change the camera projection type and capture 360 render
import omni.kit.commands
from pxr import Sdf, UsdGeom
omni.kit.commands.execute(‘CreatePrimWithDefaultXform’,
prim_type=‘Camera’,
attributes={‘focusDistance’: 400, ‘focalLength’: 24},
select_new_prim=True)
target_layer = stage.GetSessionLayer()
for prim in stage.Traverse():
if prim.IsA(UsdGeom.Camera):
print(prim.GetPath())
omni.kit.commands.execute(‘ChangeProperty’,
prop_path=Sdf.Path(‘/World/Camera.projection’),
value=‘fisheyeSpherical’,
prev=None,
target_layer=target_layer)
My objective is to write a script that will generate and position a camera with a fisheyeSpherical projection and take a 360-degree render at 5K quality. Am I headed in the right direction what are the steps i need to follow? Any assistance would be greatly appreciated.
