how to change minSdkVersion
Hello
I have change the minSdkVersion in the AndroidManifest.xml,but it doesn’t work,
I use apktool to unpack the apk file and open AndroidManifest.xml,
the seems been removed,
is any way to change the minisdk version?
By default, Nsight Tegra overrides the API levels in the manifest. Therefore to change minSdkVersion, set the General → Min Android API Level property to the desired value. You can also turn off overriding by setting the General → Override Manifest API Levels property to No.
Thank you :)
