Can not create Android project - no Min Target
My Software configuration is :
Windows 7 x64
Visual Studio 2010
NVIDIA_Nsight_Tegra_Release_2.0.0.15033
jdk1.7.0_45
NDK 10
SDK 21
apache-ant-1.9.4
Environment variables are set correct. (ANDROID_SDK_ROOT, ANDROID_NDK_ROOT, JAVA_HOME, JAVA_HOME\bin in path, ANT_HOME)
When i’m trying to create Android project, there is no “Min target” options avaliable… so Finish button is disabled.
What am i doing wrong ?
This is window what i get : [url]http://s9.postimg.org/oc8akertb/image.png[/url]
Hi, could you try upgrading to TADP 4.0r1? We’ve had several bug fixes since Nsight Tegra 2.0.0.15033 and your issue could already have been fixed.
Hi, I have the same problem with the most recent Nvidia tools under VS 2015. Marvin did you solve the issue?
Solved, see [url]https://devtalk.nvidia.com/default/topic/817510[/url]
