How to change the height of UE in AODT?
Hi, community:
Can the height of UE be modified in em simulation?
I can modify the RU height in RU property and the height will change in both UI (shown in the following picture with white mark) and clickhouse data.
when I try to modify the height of ue, i.e., 0.01m, in scenario like:
the height in scenario is the same as UI scenario:
However, the height in Table ues is still:
From the first picture, the UE in yellow mark is still 1.5m height. Then, I check the UE position that is the same with 1.5m while the RU positions change in Z axis.
I was wondering whether it is possible to change the height of UE for EM simulation, even if it requires modifying some code.
Could you provide any suggestion?
Thank you for your help.
@guofachang We will fix the issue in our upcoming AODT 1.1 release. Then you will be able to set the height of UE.
@kpasad1 Thank you for your reply. I was wondering when the new version is expected to be released.
@kpasad1 Hi, can the UE or RU size shown in UI be modified in V1.0.0?
If in indoor scenario, we hope RU and UE be smaller.
We have encountered the same issue. One alternative solution we’ve explored is manually modifying the parameters in the USD Composer. However, this approach is time-consuming and inefficient.
