Error when I try to edit waypoints for UE for UE mobility
Error Message: /BasisCurves_ue_edit_waypoints does not exist
I did follow the same procedure except for a few parameters being different.
I was running a mode 2 simulation(Simulate RAN set to true). Slots per batch : 50 and samples per slot : 1.
Could someone explain me why Am i getting that error. Did I miss any steps.
Thanks in advance.
@kpasad1 , I saw your reply for https://forums.developer.nvidia.com/t/questions-about-the-steps-to-draw-the-waypoints/310880. I guess it was supposed to be questions for this issue.
  1. were you connected to the backend worker?
  2. did the route show up as orange paths as you placed them?
  3. When you generate UE’s, the trajectories should show up. Do you see them?
  4. Is you trajectory long enough for the simulation?
  • I was connected with backend worker.
  • Yes it did show up in orange.
  • No I do not see the UEs trajectories when I generate UEs.
  • I am not sure what is minimum trajectory length, could you please let me know more about this.
Thank you
