I am using a Jetson platform (Orin Nano, NX, AGX). While jtop allows me to see the GPU memory usage per process, it does not show how much GPU usage (%) each process contributes when the overall GPU utilization is at 90%.
Is there a way to check the GPU usage percentage per process? If so, could you please provide guidance or recommend a tool?
Thank you in advance for your help.
