How to check performance of TensorRT optimised file
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I had onnx model and optimised the model using TensorRT optimisation tool.
Now I am planning to compare onnx and TensorRT optimised file.
How to compare?
Dear @alksainath.medam,
You can use trtexec to know total execution(inference) time and per layer perf timings of TRT model.
ok @SivaRamaKrishnaNV Thanks
Any tutorials how to use trtexec to know this execution time and per layer perf timing of TRT model.
I had used below link to optimise model.
https://developer.nvidia.com/docs/drive/driveworks/latest/nvsdk_dw_html/dwx_tensorRT_tool.html
Could you check /usr/src/tensorrt/bin/trtexec --help to know the profiling options?
Thanks @SivaRamaKrishnaNV
I am attaching the log file of profiling options and sharing the onnx as well as trt optimised model.
I just want to compare these two models in terms of accuracy or inference time, in any comparison means as possible.
model2cnn.trt (4.0 MB)
model2cnn.onnx (1.9 MB)
I don’t see trtexec profiling options log attached.
Sorry @SivaRamaKrishnaNV
trtexe_help (2.3 KB)
Attached now.
We have included --dumpProfile option with trtexec to report per layer perf information which seems to be missing. Could you check if --dumpProfile option works on DRIVE SW 10.0 release.
Regarding accuracy and inference time comparison, we don’t have any tools/scripts for comparing ONNX vs TRT. You may have to write your scripts on own to compare the performance on a dataset.
Okay @SivaRamaKrishnaNV
Checked --dumpProfile option getting error as unknown argument.
Attaching the log file.
for TRT performance any code is there to check performance?
Is it possible to upgrade to DRIVE OS 5.2.6 + DW 4.0 release. It has --dumpProfile option.
Thanks @SivaRamaKrishnaNV will check with my team.
