I am running the multiple parallel application and observed that GPU Shared RAM utilization is still below 2GB. How can I make a settings to start utilizing the optimal gpu shared RAM?
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
How much memory do you expect to use in the application?
Do you mean the application doesn’t use the memory?
Could you share more info about your use case with us?
