How to connect and flash Jetson Orin NX/Nano with a custom carrier board?
Hi, I am planning to buy this Connect Tech carrier board (link) for a Jetson Orin NX or Nano, I don’t know yet.
As there are no direct connectors, I was wondering how I am supposed to connect and flash the board. I found some USB 3.0 adapters (like this one) but it’s only a female port.
Also, I might develop headless on it. I might also need an Ethernet adapter I guess, right?
Any advice and criticism is welcome! For context, I am fairly new to Jetson deployment. My goal with this setup is to integrate the system on a small drone so it needs to be as light as possible.
Thank you very much in advance!
For any custom carrier board, you should check the vendor if they provided a customized BSP and process to flash.
We can only support/guide you how to use devkit to flash.
Thank you for the answer, I will contact them!
