I have a BlueField-2, model MBF2H516A-CEEOT.
I found out that the network card model is ConnectX6, and the connector model is QSFP56.
I want to connect it point-to-point to another server’s ConnectX6 (25GB) with an SFP28 connector.
I found a QSFP28 to SFP28 converter, but I couldn’t find a QSFP56 to SFP28 converter.
Can you help me with this?
Thank you!
You can use SFP28, follow below select compatible module.
