How to convert .qdrep to .nsys-rep format?
Hi everyone,
I have a profiling result saved as a .qdrep file using nsys. I need to convert it to a .nsys-rep file forma.
Is there a way to convert a .qdrep file to .nsys-rep format via nsys export or any other command?
Thanks in advance!
‘.qdrep’ is the report file name suffix used by older releases of Nsight Systems. In recent years Nsight Systems changed the report file name suffix to ‘.nsys-rep’. Backwards compatibility is retained and Nsight Systems can load report files with either suffix.
I’ll add as a note, that if you are getting .qdrep results your version of Nsight Systems is years out of date. I would strongly recommend picking up a newer version if you are able.
