I use an IMX415 camera to capture images on a Xavier NX system. The images are greenish than normal, because I have to use a lens without IR cut filter (650nm). Is there any document or tools for image color tuning ? If I install camera_override.isp, which comes from the camera vendor, the image color is even worse. So apparently this file can change the image color. After reading some online information I learned that the camera_override.isp is a configuration file for the ISP. Does Nvidia provide document and tools for generating this .isp file?
I talked to them. They cannot generate a camera_override.isp without IR filter on the lens. Because we did color correction for other cameras, I think I may be able to make a similar adjustment if Nvidia can provide the tools to me.
