How to covert TSC SOF to UTC time
Continuing the discussion from Correct way to correlate TSC to PTP to convert TSC SOF to UTC time:
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hi i’m still wondering is there any other way to convert TSC SOF to UTC time, thanks!
Dear @zhaoming.ge,
Is it like you want to sync camera timestamp and system time?
Hi @SivaRamaKrishnaNV
Thanks for your fast reply, you’re right, that’s what i wanted.
You can look at the problems I raised, it seems that there are bugs, can not be solved.
You can add wechat communication: 18667105980
hi @SivaRamaKrishnaNV is there any update? thanks!
I notice some issues when trying to sync TSC to system time. I am investigating it and update you.
Hi @SivaRamaKrishnaNV Thanks for your reply, please @ me if there’s any update.
Dear @zhaoming.ge ,
Could you share the date command output?
Also, please share below values your sample.
dwImageTimestamps imageTimestamps{};
dwSensorCamera_getImageTimestamps(&imageTimestamps, frame[i]);
                dwTime_t TSCEOFtime = imageTimestamps.tscEofTimestampUs;
dwContext_getCurrentTime(&dw_ts, m_context);
clock_gettime(CLOCK_REALTIME, &sys_ts);
int64_t sys_time = static_cast<int64_t>(sys_ts.tv_sec * 1000000 + sys_ts.tv_nsec / 1000);
 std::cout << " dwContextTimestamp : " << dw_ts << " sys-realclok : "<<sys_time << dwSensorCamera_getImageTimestamps.EOFtime "<< EOFtime >> std::endl;
Hi @SivaRamaKrishnaNV , i’m really appreciate your reply, but i’m not using dw API, i’m using nvsipl_camera and imageMetaData API to get FrameTimestamp, i’m figuring out how to convert frameCaptureTSC and frameCaptureStartTSC to system time with a reliable way, is ther any methods to do it ? thanks !
hi @SivaRamaKrishnaNV , is there any update? thanks ~
Hi @zhaoming.ge ,
Direct conversion to system time is not possible in nvsipl_camera.
How about getting TSC timestamp currently and system timestamp and then map with difference to every TSC timestamp obtained from nvsipl_camera. You can use nvpGetTimeMark to get TSC timestamp. Please see
thanks for your reply and solution, it worked on my machine. thank you so much!
