• GForce GTX 1080Ti
• DeepStream Version 5.1
• TensorRT Version 7.2.3
• NVIDIA GPU Driver Version 455
Hi I want to create a gstreamer pipeline with two branches having different FPS. The C++ code I wrote is given below
#include <iostream>
#include <string.h>
#include <gst/gst.h>
#include <gst/app/app.h>
using namespace std;
GstElement *src, *dbin, *conv, *tee, *mux, *parse, *pipeline;
GstElement *queue1,*videorate1, *conv1, *jenc1, *sink1;
GstElement *queue2,*videorate2, *conv2, *jenc2, *sink2;
GMainLoop *loop;
static gboolean
message_cb (GstBus * bus, GstMessage * message, gpointer user_data)
//Cpipeline *obj_pipeline = (Cpipeline*)user_data;
switch (GST_MESSAGE_TYPE (message)) {
case GST_MESSAGE_ERROR:{
GError *err = NULL;
gchar *name, *debug = NULL;
name = gst_object_get_path_string (message->src);
gst_message_parse_error (message, &err, &debug);
g_printerr ("ERROR: from element %s: %s\n", name, err->message);
if (debug != NULL)
g_printerr ("Additional debug info:\n%s\n", debug);
g_error_free (err);
g_free (debug);
g_free (name);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:{
GError *err = NULL;
gst_message_parse_warning (message, &err, &debug);
if (debug != NULL)
g_error_free (err);
g_free (debug);
g_free (name);
break;
case GST_MESSAGE_EOS:
g_print ("\nGot EOS\n");
break;
default:
break;
return TRUE;
static void pad_added_handler (GstElement *src, GstPad *new_pad, gpointer x)
GstPad *sink_pad = gst_element_get_static_pad (parse, "sink");
GstPadLinkReturn ret;
GstCaps *new_pad_caps = NULL;
GstStructure *new_pad_struct = NULL;
const gchar *new_pad_type = NULL;
/* If our converter is already linked, we have nothing to do here */
if (gst_pad_is_linked (sink_pad)) {
g_print ("We are already linked. Ignoring.\n");
goto exit;
new_pad_caps = gst_pad_get_current_caps (new_pad);
new_pad_struct = gst_caps_get_structure (new_pad_caps, 0);
new_pad_type = gst_structure_get_name (new_pad_struct);
if (!g_str_has_prefix (new_pad_type, "video/x-h264")) {
g_print ("It has type '%s' which is not raw audio. Ignoring.\n", new_pad_type);
goto exit;
ret = gst_pad_link (new_pad, sink_pad);
if (GST_PAD_LINK_FAILED (ret)) {
g_print ("Type is '%s' but link failed.\n", new_pad_type);
goto exit;
exit:
/* Unreference the new pad's caps, if we got them */
if (new_pad_caps != NULL)
gst_caps_unref (new_pad_caps);
/* Unreference the sink pad */
gst_object_unref (sink_pad);
int main()
gst_init (NULL, NULL);
pipeline = gst_pipeline_new (NULL);
src = gst_element_factory_make ("filesrc", NULL);
mux = gst_element_factory_make("qtdemux",NULL);
parse = gst_element_factory_make("h264parse",NULL);
dbin = gst_element_factory_make ("nvv4l2decoder", NULL);
conv = gst_element_factory_make ("nvvideoconvert", NULL);
tee = gst_element_factory_make ("tee", NULL);
std::string url = "VD19_peoplewalking.mp4";
if (!pipeline || !src || !dbin || !conv || !tee || !mux || !parse) {
g_error ("Failed to create elements");
return -1;
g_object_set (src, "location", url.c_str(), NULL);
gst_bin_add_many (GST_BIN (pipeline), src, dbin, mux, parse, conv, tee, NULL);
if (!gst_element_link_many(src,mux,NULL) || !gst_element_link_many(parse,dbin,conv, tee,NULL) )//|| !gst_element_link_many (conv, tee, NULL))
g_error("Failed to link elements");
return -3;
g_signal_connect (mux, "pad-added", G_CALLBACK (pad_added_handler), NULL);
//First Branch creation
GstPadTemplate *templ;
templ =
gst_element_class_get_pad_template (GST_ELEMENT_GET_CLASS (tee),
"src_%u");
GstPad *teepad1 = gst_element_request_pad (tee, templ, NULL, NULL);
queue1 = gst_element_factory_make ("queue", NULL);
videorate1 = gst_element_factory_make("videorate",NULL);
conv1 = gst_element_factory_make ("nvvideoconvert", NULL);
//jenc = gst_element_factory_make ("jpegenc",NULL);
sink1 = gst_element_factory_make ("autovideosink", NULL);
//sink = gst_element_factory_make ("appsink", NULL);
g_object_set (G_OBJECT(videorate1), "rate", 1.0, NULL);
gst_bin_add_many (GST_BIN (pipeline), queue1, videorate1, conv1, sink1, NULL);
if (!gst_element_link_many ( queue1, conv1, videorate1, sink1, NULL))
g_error ("Failed to link elements");
GstPad *sinkpad = gst_element_get_static_pad ( queue1, "sink");
gst_pad_link ( teepad1, sinkpad);
gst_object_unref (sinkpad);
//First Branch creation ends
//Second Branc
GstPadTemplate *templ2;
templ2 =
"src_%u");
GstPad *teepad2 = gst_element_request_pad (tee, templ2, NULL, NULL);
queue2 = gst_element_factory_make ("queue", NULL);
videorate2 = gst_element_factory_make("videorate",NULL);
conv2 = gst_element_factory_make ("nvvideoconvert", NULL);
sink2 = gst_element_factory_make ("autovideosink", NULL);
g_object_set (G_OBJECT(videorate2), "rate", 0.5, NULL);
gst_bin_add_many (GST_BIN (pipeline), queue2, videorate2, conv2, sink2, NULL);
if (!gst_element_link_many ( queue2, conv2, videorate2, sink2, NULL))
GstPad *sinkpad2 = gst_element_get_static_pad ( queue2, "sink");
gst_pad_link ( teepad2, sinkpad2);
gst_object_unref (sinkpad2);
//Second brach creation ends
GstBus *bus;
loop = g_main_loop_new (NULL, FALSE);
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
gst_bus_add_signal_watch (bus);
g_signal_connect (G_OBJECT (bus), "message", G_CALLBACK (message_cb), NULL);
gst_object_unref (GST_OBJECT (bus));
gst_element_set_state (pipeline, GST_STATE_PLAYING);
g_main_loop_run (loop);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_main_loop_unref (loop);
gst_object_unref (pipeline);
I am able to run the code but the streams are not played as expected. Both streams get stuck in between while running the code.
Am I missing something?
