Hi,any body did the test?
my environment :
server1
ibstat
CA ‘mlx4_0’
CA type: MT4099
Number of ports: 2
Firmware version: 2.11.500
Hardware version: 0
Node GUID: 0xf4521403007dc820
System image GUID: 0xf4521403007dc823
Port 1:
State: Active
Physical state: LinkUp
Rate: 56
Base lid: 10
LMC: 0
SM lid: 2
Capability mask: 0x02514868
Port GUID: 0xf4521403007dc821
Link layer: InfiniBand
Port 2:
State: Active
Rate: 56
Base lid: 15
LMC: 0
SM lid: 56
Port GUID: 0xf4521403007dc822
server 2
ibstat
CA ‘mlx4_0’
CA type: MT4099
Number of ports: 2
Firmware version: 2.32.5180
Hardware version: 0
Node GUID: 0x248a070300f041f0
System image GUID: 0x248a070300f041f3
Port 1:
State: Active
Rate: 56
Base lid: 25
LMC: 0
SM lid: 2
Port GUID: 0x248a070300f041f1
Port 2:
State: Active
Rate: 56
Base lid: 4
LMC: 0
SM lid: 56
Port GUID: 0x248a070300f041f2
ib switch :
switch-bbb978 [standalone: master] (config) # show ib partition
Default
PKey = 0x7FFF
defmember = full
ipoib = yes
members
GUID=‘ALL’ member=‘default’
under the default partition, ibping is ok .now I do not want to server1 can ping server2 。
i confiure like this on switch
Default
PKey = 0x7FFF
defmember = full
ipoib = yes
members
test1
PKey = 0x0020
defmember = limited
ipoib = no
members
GUID=‘24:8a:07:03:00:f0:41:f1’ member=‘limited’
GUID=‘f4:52:14:03:00:7d:c8:21’ member=‘limited’
if i delete the default partition, other node can be effected.
if i keep the default partition,server 1 still can ibping server 2 ,how to set the priority ?
