Hi Isaac ROS team,
I’m currently developing Python-based ROS 2 nodes inside the isaac_ros_dev-x86_64
container, using the run_dev.sh
environment.
I’d like to debug my ROS 2 Python nodes using pdb
or the Visual Studio Code Python debugger. However, I’ve had trouble getting debugger mode to work correctly from inside the container. I’ve tried:
- Adding
pdb.set_trace()
in the node script: works, but not convenient for full debugging. - Launching
python3 -m debugpy --listen 5678 --wait-for-client my_node.py
and attaching from VS Code: partially works. - Using
launch.json
in VS Code Remote Containers to run the node directly: fails withCould not find debugpy path
Questions:
- What is the officially recommended way to enable Python debugger mode inside the Isaac ROS dev container?
- Is it possible to debug a ROS 2 Python node using VS Code
launch.json
directly in the container environment? - Are there specific environment variables or entrypoints I should use to properly initialize the ROS environment before launching the node via debugger?
Any guidance or example configurations would be greatly appreciated!
Thanks in advance.
