how to degrade cuDNN from 7.1 to 7.0
When I use tesorflow with gpu, there is an error raised:
E tensorflow/stream_executor/cuda/cuda_dnn.cc:378] Loaded runtime CuDNN library: 7103 (compatibility version 7100) but source was compiled with 7004 (compatibility version 7000).
cuda9 is installed now,
I try to install with: sudo dpkg -i libcudnn7-dev_7.0.5.15-1+cuda9.0_amd64.deb
and got error:
dpkg: dependency problems prevent configuration of libcudnn7-dev:
libcudnn7-dev depends on libcudnn7 (= 7.0.5.15-1+cuda9.0); however:
Version of libcudnn7 on system is 7.1.3.16-1+cuda9.1.
dpkg: error processing package libcudnn7-dev (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
libcudnn7-dev
how should I do to make my program successfully run?
