0
I’m using CUDA in my application and are dependent on the installed CUDA driver. So at the beginning of the application I’m able to check all preconditions
- get the CUDA/GPU device
- check the compute capability
- get the installed driver
and then inform the user if some conditions are not met. Only the driver version bugs me a little. I can show the user which version is required and guide him to the nvidia website. Afterwards the user needs to select the GPU and the windows version.
But many customers are not aware and inexperienced what to do and we get many calls what to select on the website. So what I wanted to do is that I can at least preselect what they need to download, which means I preselect the graphics device and the windows version.
Of course the best option would be that can download the driver directly without going to the website.
So here’s my question
- Is there a way to preselect the driver required options on the website if you know your GPU?
or
- Is there a way where I can download the driver directly without having to go to the website?
