Please advise, trying to download latest long lived branch for Linux x86_64, but clicking save button seems to not do much. Don’t know where it downloads to, nothing in my Downloads folder on the Windows system I am using to connect to the NVIDIA website.
Is there a “wget” command string to download the latest long lived branch directly to a Linux system connected to the net?
I also need to download the compatible CUDA for Linux x86_64.
Hi Bruce,
There are direct links to the .run packages in the driver release announcement posts. You can find links to the latest ones from https://devtalk.nvidia.com/default/topic/533434/linux/current-graphics-driver-releases/
Someone mentioned a file, NVIDIA-Linux-x86_64-440.64.run does anyone have a “wget” command string to pull that down to my Linux workstation?
Also need help getting CUDA installable.
wget https://download.nvidia.com/XFree86/Linux-x86_64/440.64/NVIDIA-Linux-x86_64-440.64.run
Edit: Found it, there are instructions on how to download the CUDA installer using wget from here, once you select the platform and format you want it in: CUDA Toolkit 11.7 Update 1 Downloads | NVIDIA Developer
Thanks Aaron, that worked fine after I supplied --no-certificate-check.
May I ask for another wget to obtain the compatible CUDA package for that latest long lived branch for X86_64 ?
Much obliged,
Bruce Cook
Thanks, I have installed NVIDIA driver.
Also downloaded the run script for CUDA, got this error when running, please advise:
[root@eweegc299 ~]# more /var/log/cuda-installer.log
[INFO]: Driver not installed.
[INFO]: Checking compiler version…
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 4.8.5 20150623 (Red Hat 4.8.5-39) (GCC)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 440.33.01
[INFO]: Executing NVIDIA-Linux-x86_64-440.33.01.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-ve
rsion-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 440.33.01 failed, quitting
Thanks,
Bruce Cook
Tried changing to non-graphics mode and running the CUDA script again, got this:
[INFO]: Driver
[INFO]: 440.33.01
e --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 36096
Please advise.
Thanks,
Bruce Cook
