How to disable ouput of verbose message when creating trt model from onnx model
Description
I use tensorrt API to converse ONNX model to tensorrt engine model, it takes much time, so I want to disable the API to print building message to terminal ,how to set the API function?
Environment
TensorRT Version: v8.0.1.6
GPU Type: RTX3060
Nvidia Driver Version: V511
CUDA Version: 11.3
CUDNN Version: 8.2
Operating System + Version: ubuntu20.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Function
   /// Parse onnx file and create a TRT engine
  nvinfer1::ICudaEngine *createCudaEngine(const std::string
  &onnxFileName, nvinfer1::ILogger &logger)
     using namespace std;
     using namespace nvinfer1;
    // unique_ptr<IBuilder, Destroy<IBuilder>>
    builder{createInferBuilder(logger)};
    builder(createInferBuilder(logger)); // use () also ok
    unique_ptr<INetworkDefinition, Destroy<INetworkDefinition>>
    network{
    builder->createNetworkV2(1U <<
    (unsigned)NetworkDefinitionCreationFlag::kEXPLICIT_BATCH)};
    unique_ptr<nvonnxparser::IParser, Destroy<nvonnxparser::IParser>>
    parser{ nvonnxparser::createParser(*network, logger)};
    if (!parser->parseFromFile(onnxFileName.c_str(), static_cast<int>
      (ILogger::Severity::kINFO)))
       throw runtime_error("ERROR: could not parse ONNX model " +
        onnxFileName + " !");
    // Modern version with config
    unique_ptr<IBuilderConfig, Destroy<IBuilderConfig>> config(builder-
     >createBuilderConfig());
   // This is needed for TensorRT 6, not needed by 7 !
   config->setMaxWorkspaceSize(64 * 1024 * 1024);
   return builder->buildEngineWithConfig(*network, *config);
 main(){
     myLogger logger;
      std::string onnx_filepath = "./model/resnet.onnx";
      unique_ptr<ICudaEngine, Destroy<ICudaEngine>>
      engine(createCudaEngine(onnx_filepath, logger));
Does Tensorrt API provide such options to disable verbose message?
Please refer to the following.
https://docs.nvidia.com/deeplearning/tensorrt/api/c_api/classnvinfer1_1_1_i_logger.html
Thank you.
it is helpful
