How to disable SMMU for pcie5?
I read the similar topics and went through the following steps:
  1. Download Linux_for_Tegra, kernel source and sample rootfs from this link https://developer.nvidia.com/embedded/linux-tegra-r3271
  2. I extracted rootfs to Linux_for_tegra/rootfs
  3. Removed this strings from tegra194-soc-pcie.dtsi
    iommus = <&smmu TEGRA_SID_PCIE5>;
    dma-coherent;
  4. In arm-smmu-t19x.c
    reg = readl_relaxed(ARM_SMMU_GR0_NS(smmu) +
    ARM_SMMU_GR0_sCR0);
    /* Enable fault reporting /
    -reg |= (sCR0_GFRE | sCR0_GFIE | sCR0_GCFGFRE | sCR0_GCFGFIE |
    sCR0_USFCFG);
    +reg |= (sCR0_GFRE | sCR0_GFIE | sCR0_GCFGFRE | sCR0_GCFGFIE);
    Disable Unidentified stream fault reporting */
    +reg &= ~(sCR0_USFCFG);
  5. ./nvbuild.sh -o $HOME/Desktop/kernel_out/ and copy *.dtb *.dtbo and Image to Linux_for_Tegra dir
  6. sudo ./apply_binaries.sh
  7. sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
    The script succseed and after rebooting jetson didnt start the system.
    So what am i doing wrong? I tryed to change /bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg in Linux_for_Tegra as in the pcie smmu issue - #6 by vidyas but nothing changed.
The tip is for Xavier and may not work for Xavier NX. Is there a reason to disable SMMU? We don’t actually recommend do this.
There is the same tips for Xavier NX here How to disable IOMMU on Xavier NX? - #27 by WayneWWW
What kind of error did you see when it “stuck in boot”
Update:
Instead of ./nvbuild.sh i compiled .dtb, image, modules. Next I moved Image and .dtb to Linux_for_Tegra/arch/arm64/kernel/ , installed modules and moved them to rootfs dir.
So after that flashing went well and the system starts with gui, but with default device tree and SMMU still there.
I think that Im doing smth wrong with Linux for Tegra or flashing process.
