I have a project use imx185 sensor at jetson TX1 R28.2
How to correctly define “clock-names”this field ?
I use “clk_out_3”,or "“extperiph1”,
Which is RIGHT?
the device c source is below
static int imx185_power_get(struct imx185 *priv)
struct camera_common_power_rail *pw = &priv->power;
struct camera_common_pdata *pdata = priv->pdata;
const char *mclk_name;
struct clk *parent;
int err = 0;
mclk_name = priv->pdata->mclk_name ?
priv->pdata->mclk_name : "extperiph1";
pw->mclk = devm_clk_get(&priv->i2c_client->dev, mclk_name);
if (IS_ERR(pw->mclk)) {
dev_err(&priv->i2c_client->dev,
"unable to get clock %s\n", mclk_name);
return PTR_ERR(pw->mclk);
parent = devm_clk_get(&priv->i2c_client->dev, "pllp_grtba");
if (IS_ERR(parent))
dev_err(&priv->i2c_client->dev, "devm_clk_get failed for pllp_grtba");
else
clk_set_parent(pw->mclk, parent);
pw->reset_gpio = pdata->reset_gpio;
pw->state = SWITCH_OFF;
return err;
The dtsi file is below:
imx185_a@1a {
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
clock-names = "clk_out_3";
clock-frequency = <24000000>;
mclk = "clk_out_3";
reset-gpios = <&gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
