hello I want to use isaacgym environment to train my own agent
to complete this, I modify cartpole_task.py to multiple environment.
so I change num_envs=2
in __init__
method like below code
class CartpoleTask(BaseTask):
def __init__(
self,
name,
headless,
offset=None,
) -> None:
self.headless = headless
# task-specific parameters
self._cartpole_position = [0.0, 0.0, 2.0]
self._cartpole_position2 = [2.0, 0.0, 2.0]
self._reset_dist = 3.0
self._max_push_effort = 400.0
# values used for defining RL buffers
self._num_observations = 4
self._num_actions = 1
self._device = "cpu"
self.num_envs = 2
# a few class buffers to store RL-related states
self.obs = torch.zeros((self.num_envs, self._num_observations))
self.resets = torch.zeros((self.num_envs, 1))
# set the action and observation space for RL
self.action_space = spaces.Box(np.ones(self._num_actions) * -1.0, np.ones(self._num_actions) * 1.0)
self.observation_space = spaces.Box(np.ones(self._num_observations) * -np.Inf, np.ones(self._num_observations) * np.Inf)
# trigger __init__ of parent class
BaseTask.__init__(self, name=name, offset=offset)
and add another cartpole like this
def set_up_scene(self, scene) -> None:
# retrieve file path for the Cartpole USD file
# assets_root_path = get_assets_root_path()
usd_path = "/home/nscl2004/Study/rl/stb/skrl/examples/usd/cartpole.usd"
usd_path = assets_root_path + "/Isaac/Robots/Cartpole/cartpole.usd"
# add the Cartpole USD to our stage
create_prim(prim_path="/World/Cartpole", prim_type="Xform", position=self._cartpole_position)
create_prim(prim_path="/World/Cartpole2", prim_type="Xform", position=self._cartpole_position2)
add_reference_to_stage(usd_path, "/World/Cartpole")
add_reference_to_stage(usd_path, "/World/Cartpole2")
# create an ArticulationView wrapper for our cartpole - this can be extended towards accessing multiple cartpoles
self._cartpoles = ArticulationView(prim_paths_expr="/World/Cartpole*", name="cartpole_view")
# add Cartpole ArticulationView and ground plane to the Scene
scene.add(self._cartpoles)
scene.add_default_ground_plane()
self.sd_helper = None
self.viewport_window = None
self._set_camera()
# set default camera viewport position and target
# self.set_initial_camera_params()
and excute train code from skrl tutorial but I met this error.
File "cartpole_example_skrl.py", line 113, in <module>
trainer.train()
File "/home/user/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/skrl/trainers/torch/sequential.py", line 54, in train
self.single_agent_train()
File "/home/user/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/skrl/trainers/torch/base.py", line 208, in single_agent_train
next_states, rewards, dones, infos = self.env.step(actions)
File "/home/user/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/skrl/envs/torch/wrappers.py", line 322, in step
observation, reward, done, info = self._env.step(self._tensor_to_action(actions))
File "/home/user/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/skrl/envs/torch/wrappers.py", line 309, in _tensor_to_action
return np.array(actions.cpu().numpy(), dtype=space.dtype).reshape(space.shape)
ValueError: cannot reshape array of size 2 into shape (1,)
/home/user/.local/share/ov/pkg/isaac_sim-2022.1.0/python.sh: line 46: 60952 Segmentation fault (core dumped) $python_exe "$@" $args
There was an error running python
I really hard to understand this error because I think if I set num_envs
value as 2, trainer is automatically matching observation shape.
anyone who solve an error similar to this case??
