Customization of IsaacSim Deep RL example
Hi.
I am customizing Deep RL environment for my manipulator, and I’ve been referencing an cartpole example of IsaaSim 2022.2.0 ver below.
/home/my_com/.local/share/ov/pkg/isaac_sim/2022.2.0/standalone_examples/api/omni.isaac.gym/cartpole_task.py & cartpole_train.py
I have a 2 questions.
Q1) Is there any check point function ?
model.save(log_dir + “/jetbot_policy”)
The above python code in “cartpole_train.py” didn’t work, so the check point zip files about polices are not saved.
I remembered that the previous version (IsaacSim 2021.2.1) can save the intermediate policies by .zip files.
Q2) Is there any methods to multiply (clone) the learning environment ?
“cartpole_task.py” has a parameter about multi environment “self.num_envs = 1”, but it doesn’t work when I change the number of envs.
How can I fix these problems ?
Thank you.
Hi @swimpark
I have not encountered any problems in saving the checkpoint to .zip as follow for cartpole_train.py using sb3-v1.6.2. Make sure this method is called at some point during the script execution
model.learn(total_timesteps=100)
log_dir = "test"
model.save(log_dir + "/jetbot_policy")
Well, in any case, you can always move to another RL library with a higher level (at least for me) of code control such as skrl. I know, I am 100% biased 😅
For question 2, please refer this post, it may help
Hi @toni.sm ,
I am really appreciate the rapid reply.
I confirmed that the customizing example is working well, and I customized it in my case.
However, I am not sure the learning process is working well, because I cannot check the prim as video below.
I created my robot (/World/M1013_0) using <creat_prim> and also add the Inverse kinematics target (/World/M1013_0/Target).
The positions of end_effector and target position are collected by <get_prim_property> in [def get_observation]. (“/World/M1013_0/TCP” and “/World/M1013_0/Target”, respectably)
And then, the target is deleted and created again when the reset is 1 using <delete_prim> in [def reset].
This is the full code for my “task_train.py”.
from omni.isaac.core.utils.nucleus import get_assets_root_path
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.tasks.base_task import BaseTask
from omni.isaac.core.articulations import ArticulationView
from omni.isaac.core.utils.prims import create_prim, delete_prim
from omni.isaac.core.utils.viewports import set_camera_view
from omni.isaac.cloner import GridCloner
from omni.isaac.core.utils.prims import get_prim_property
import omni.kit
import gym
from gym import spaces
import numpy as np
import torch
import math
import random
class RobotTask(BaseTask):
    def __init__(self, name, offset=None) -> None:
        # task-specific parameters
        self._robot_position = [0.0, 0.0, 0.2]
        self._reset_dist = 2
        self._success_dist = 0.02
        self._step = 0
        self._max_episode_length = 1000
        self._time_penalty = -0.01
        self._dist_reward_scale = 0.1
        self._target_position = []
        # values used for defining RL buffers
        self._num_observations = 13 #joint_curret(6)/Position_EE(3)/Position_target(3)
        self._num_actions = 6 #delta joints(6)
        self._device = "cpu"
        self.num_envs = 4
        # a few class buffers to store RL-related states
        self.obs = torch.zeros((self.num_envs, self._num_observations))
        self.resets = torch.zeros((self.num_envs, 1))
        # set the action and observation space for RL
        self.action_space = spaces.Box(np.ones(self._num_actions) * -0.0174, np.ones(self._num_actions) * 0.0174)
        self.observation_space = spaces.Box(
            np.ones(self._num_observations) * -np.Inf, np.ones(self._num_observations) * np.Inf
        # trigger __init__ of parent class
        BaseTask.__init__(self, name=name, offset=offset)
    def set_up_scene(self, scene) -> None:
        # retrieve file path for the Robot USD file
        usd_path = "omniverse://localhost/Isaac/Robots/K-CLOUD/robots/AMR_M1013/mark5.usd"
        create_prim(prim_path="/World/M1013_0", prim_type="Xform", position=self._robot_position)
        self._target_position = [random.uniform(0.4, 0.6), random.uniform(-0.3, 0.3), random.uniform(0.55, 1.0)]
        create_prim(prim_path="/World/M1013_0/Target", prim_type="Xform", position=self._target_position)
        add_reference_to_stage(usd_path, "/World/M1013_0")
        # create a GridCloner instance
        cloner = GridCloner(spacing=5)
        target_paths = cloner.generate_paths("/World/M1013", self.num_envs)
        print(target_paths)
        position_offsets = np.zeros([self.num_envs, 3]) + np.array([0, 0, self._robot_position[2]])
        cloner.clone(source_prim_path="/World/M1013_0", prim_paths=target_paths, position_offsets=position_offsets)
        # create an ArticulationView wrapper for our robot - this can be extended towards accessing multiple cartpoles
        self._robots = ArticulationView(prim_paths_expr="/World/M1013*", name="robot_view")
        # add Robot ArticulationView and ground plane to the Scene
        scene.add(self._robots)
        scene.add_default_ground_plane()
        # set default camera viewport position and target
        self.set_initial_camera_params()
    def set_initial_camera_params(self, camera_position=[10, 10, 3], camera_target=[0, 0, 0]):
        set_camera_view(eye=camera_position, target=camera_target, camera_prim_path="/OmniverseKit_Persp")
    def post_reset(self):
        self._joint1_dof_idx = self._robots.get_dof_index("joint1")
        self._joint2_dof_idx = self._robots.get_dof_index("joint2")
        self._joint3_dof_idx = self._robots.get_dof_index("joint3")
        self._joint4_dof_idx = self._robots.get_dof_index("joint4")
        self._joint5_dof_idx = self._robots.get_dof_index("joint5")
        self._joint6_dof_idx = self._robots.get_dof_index("joint6")
        # randomize all envs
        indices = torch.arange(self._robots.count, dtype=torch.int64, device=self._device)
        self.reset(indices)
    def reset(self, env_ids=None):
        if env_ids is None:
            env_ids = torch.arange(self.num_envs, device=self._device)
        num_resets = len(env_ids)
        delete_prim(prim_path="/World/M1013_0/Target")
        self._step = 0
        # Initialized DOF positions
        dof_pos = torch.zeros((num_resets, self._robots.num_dof), device=self._device)
        dof_pos[:, self._joint1_dof_idx] = 0 * torch.rand(num_resets, device=self._device)
        dof_pos[:, self._joint2_dof_idx] = 0 * torch.rand(num_resets, device=self._device)
        dof_pos[:, self._joint3_dof_idx] = 0 * torch.rand(num_resets, device=self._device)
        dof_pos[:, self._joint4_dof_idx] = 0 * torch.rand(num_resets, device=self._device)
        dof_pos[:, self._joint5_dof_idx] = 0 * torch.rand(num_resets, device=self._device)
        dof_pos[:, self._joint6_dof_idx] = 0 * torch.rand(num_resets, device=self._device)
        # print("dof_pos = ", dof_pos)
        self._target_position = [random.uniform(0.4, 0.6), random.uniform(-0.3, 0.3), random.uniform(0.75, 1.2)]
        # apply resets
        indices = env_ids.to(dtype=torch.int32)
        self._robots.set_joint_positions(dof_pos, indices=indices)
        # bookkeeping
        self.resets[env_ids] = 0
    def pre_physics_step(self, actions) -> None:  # Action function
        reset_env_ids = self.resets.nonzero(as_tuple=False).squeeze(-1)
        if len(reset_env_ids) > 0:
            self.reset(reset_env_ids)
        actions = torch.tensor(actions)
        j_current = self._robots.get_joint_positions()
        delta_joint = torch.zeros((self._robots.count, self._robots.num_dof), dtype=torch.float32, device=self._device)
        # print("robot count = ", self._robots.count, "j_current = ", j_current, "action = ", actions)
        delta_joint[:, self._joint1_dof_idx] = j_current[:, 0] + actions[:, 0]
        delta_joint[:, self._joint2_dof_idx] = j_current[:, 1] + actions[:, 1]
        delta_joint[:, self._joint3_dof_idx] = j_current[:, 2] + actions[:, 2]
        delta_joint[:, self._joint4_dof_idx] = j_current[:, 3] + actions[:, 3]
        delta_joint[:, self._joint5_dof_idx] = j_current[:, 4] + actions[:, 4]
        delta_joint[:, self._joint6_dof_idx] = j_current[:, 5] + actions[:, 5]
        indices = torch.arange(self._robots.count, dtype=torch.int32, device=self._device)
        self._step += 1
        self._robots.set_joint_positions(delta_joint, indices=indices)
    def get_observations(self): #Observation function
        dof_pos = self._robots.get_joint_positions()
        EE_pos =  get_prim_property(prim_path = "/World/M1013_0/TCP", property_name =  "xformOp:translate")
        Target_pos =  get_prim_property(prim_path = "/World/M1013_0/Target", property_name =  "xformOp:translate")
        if Target_pos is not None:
            self.distance = np.linalg.norm(Target_pos  -  EE_pos)
        else:
            self.distance = 0
        # collect pole and cart joint positions for observation
        j1_pos = dof_pos[:, self._joint1_dof_idx]
        j2_pos = dof_pos[:, self._joint2_dof_idx]
        j3_pos = dof_pos[:, self._joint3_dof_idx]
        j4_pos = dof_pos[:, self._joint4_dof_idx]
        j5_pos = dof_pos[:, self._joint5_dof_idx]
        j6_pos = dof_pos[:, self._joint6_dof_idx]
        self.obs[:, 0] = j1_pos
        self.obs[:, 1] = j2_pos
        self.obs[:, 2] = j3_pos
        self.obs[:, 3] = j4_pos
        self.obs[:, 4] = j5_pos
        self.obs[:, 5] = j6_pos
        self.obs[:, 6] = EE_pos[0]
        self.obs[:, 7] = EE_pos[1]
        self.obs[:, 8] = EE_pos[2]
        self.obs[:, 9] = Target_pos[0]
        self.obs[:, 10] = Target_pos[1]
        self.obs[:, 11] = Target_pos[2]
        self.obs[:, 12] = self.distance
        # print("OBS=", self.obs, "obs[:,12] = ", self.obs[:, 12])
        return self.obs
    def calculate_metrics(self) -> None: # Reward function
        distance = self.obs[:, 12]
        # compute reward based on distance btw target and end-effector
        if distance is not None:
            reward = 1.0 / (1.0 + distance ** 2)
            reward *= reward
            reward = torch.where(distance <= self._success_dist, reward * 5, reward)
        # apply a penalty if cart is too far from center
        reward = torch.where(torch.abs(distance) > self._reset_dist, torch.ones_like(reward) * -10.0, self._dist_reward_scale * reward  - self._time_penalty)
        #print("Time step = ", self._step, "Reward = ", reward, "Distance = ", distance, "reward.item = ", reward.item())
        return reward
    def is_done(self) -> None: # Reset function
        # reset the robot if cart has reached reset_dist or pole is too far from upright
        resets = torch.where(torch.abs(distance) > self._reset_dist, 1, 0)
        resets = torch.where(torch.tensor(self._step) > self._max_episode_length - 1, 1, resets)
        self.resets = resets
        # print("Is Done = ", resets, "Type = ", resets.type())
        return resets
My question is whether the method above has no logical error.
Is it ok to create, delete, and get the prim property from only “/World/M1013_0/Target” or should I change the method for it ?
Hi @swimpark
First, I really recommend you move your implementation to the RL Framework defined in the OmniIsaacGymEnvs for working with multiples environments in Isaac Sim rather than using the customized wrapper (I only was defined to show that is possible to do it).
Regarding your implementation, don’t delete target objects and create them, just teleport them when necessary. In addition, for performance reasons (and because get_prim_property function will not work if fabric is enabled), use View classes to obtain the positions and build the observation.
