I have been following the tutorial for training the Jetbot in Isaac Sim using Reinforcement Learning and I am working on modifying the code to fit the NVIDIA Carter V1 robot navigating a city environment. My focus is on the simulation aspect and not on the physical robot that they have setup for the Jetbot. Currently, I have edited the Jetbot class to fit the Carter robot and modified the location of the files in the code. I have completed that step but I am facing a concern.
I would like to use my own City USD file in the Enivronment code, but that code (referenced below) is creating an environment from scratch. I don’t want to create a new environment from scratch as I already have my USD file setup along with the robot in Isaac Sim. I was curious to know, is there a way that I can import my USD file into the code with a specific Omni Kit USD command, instead of having to build the environment completely from scratch? I look forward to hearing your advice.
This is the tutorial that inspired me for my project: Training Your JetBot in NVIDIA Isaac Sim | NVIDIA Developer Blog
Github for IsaacSim Code: jetbot/isaacsim_patch at master · hailoclu/jetbot · GitHub
#jetbotenv.py
import carb
import omni
import numpy as np
from omni.isaac.utils.scripts.nucleus_utils import find_nucleus_server
from pxr import UsdGeom, Gf, Sdf, PhysxSchema, PhysicsSchema, PhysicsSchemaTools
from jetbot_city.road_map import *
from jetbot_city.road_map_path_helper import *
from jetbot_city.road_map_generator import *
from omni.isaac.synthetic_utils import DomainRandomization
import math
class Environment:
def __init__(self, omni_kit, z_height=0):
self.omni_kit = omni_kit
result, nucleus_server = find_nucleus_server()
if result is False:
carb.log_error(
"Could not find nucleus server with /Isaac folder. Please specify the correct nucleus server in experiences/isaac-sim-python.json"
return
result, nucleus_server = find_nucleus_server("/Library/Props/Road_Tiles/Parts/")
if result is False:
carb.log_error(
"Could not find nucleus server with /Library/Props/Road_Tiles/Parts/ folder. Please refer to the documentation to aquire the road tile assets"
return
# 1=I 2=L 3=T, 4=X
self.tile_usd = {
0: None,
1: {"asset": nucleus_server + "/Library/Props/Road_Tiles/Parts/p4336p01.usd", "offset": 180},
2: {"asset": nucleus_server + "/Library/Props/Road_Tiles/Parts/p4342p01.usd", "offset": 180},
3: {"asset": nucleus_server + "/Library/Props/Road_Tiles/Parts/p4341p01.usd", "offset": 180},
4: {"asset": nucleus_server + "/Library/Props/Road_Tiles/Parts/p4343p01.usd", "offset": 180},
} # list of tiles that can be spawned
self.texture_list = [
nucleus_server + "/Isaac/Samples/DR/Materials/Textures/checkered.png",
nucleus_server + "/Isaac/Samples/DR/Materials/Textures/marble_tile.png",
nucleus_server + "/Isaac/Samples/DR/Materials/Textures/picture_a.png",
nucleus_server + "/Isaac/Samples/DR/Materials/Textures/picture_b.png",
nucleus_server + "/Isaac/Samples/DR/Materials/Textures/textured_wall.png",
nucleus_server + "/Isaac/Samples/DR/Materials/Textures/checkered_color.png",
self.tile_size = [25.0, 25.0]
# 1=UP, 2 = DOWN, 3 = LEFT, 4= RIGHT
self.direction_map = {1: 180, 2: 0, 3: -90, 4: 90}
self.prims = [] # list of spawned tiles
self.height = z_height # height of the ground tiles
self.tiles = None
self.state = None
# because the ground plane is what the robot drives on, we only do this once. We can then re-generate the road as often as we need without impacting physics
self.setup_physics()
self.road_map = None
self.road_path_helper = None
self.map_generator = LoopRoadMapGenerator()
contents = omni.client.list(nucleus_server + "/Isaac/Props/Sortbot_Housing/Materials/Textures/")[1]
for entry in contents:
self.texture_list.append(
nucleus_server + "/Isaac/Props/Sortbot_Housing/Materials/Textures/" + entry.relative_path
contents = omni.client.list(nucleus_server + "/Isaac/Props/YCB/Axis_Aligned/")[1]
names = []
loaded_paths = []
if not entry.flags & omni.client.Flags.CAN_HAVE_CHILDREN:
names.append(nucleus_server + "/Isaac/Props/YCB/Axis_Aligned/" + entry.relative_path)
loaded_paths.append("/World/DR/mesh_component/mesh_" + entry.relative_path[0:-4])
print(loaded_paths)
self.omni_kit.create_prim("/World/Floor", "Xform")
cubeGeom = UsdGeom.Cube.Define(stage, "/World/Floor/thefloor")
cubeGeom.CreateSizeAttr(300)
offset = Gf.Vec3f(75, 75, -150.1)
cubeGeom.AddTranslateOp().Set(offset)
# Create a sphere room so the world is not black
self.omni_kit.create_prim("/World/Room", "Sphere", attributes={"radius": 1e3})
prims = []
self.dr = DomainRandomization()
self.dr.toggle_manual_mode()
self.dr.create_mesh_comp(prim_paths=prims, mesh_list=names, mesh_range=[1, 1])
self.omni_kit.update(1 / 60.0)
print("waiting for materials to load...")
while self.omni_kit.is_loading():
lights = []
for i in range(5):
prim_path = "/World/Lights/light_" + str(i)
prim_path,
"SphereLight",
translation=(0, 0, 200),
rotation=(0, 0, 0),
attributes={"radius": 10, "intensity": 1000.0, "color": (1.0, 1.0, 1.0)},
lights.append(prim_path)
frames = 1
# enable randomization for environment
self.dr.create_movement_comp(prim_paths=loaded_paths, min_range=(0, 0, 15), max_range=(150, 150, 15))
self.dr.create_rotation_comp(prim_paths=loaded_paths)
self.dr.create_visibility_comp(prim_paths=loaded_paths, num_visible_range=(15, 15))
self.dr.create_light_comp(light_paths=lights)
self.dr.create_movement_comp(prim_paths=lights, min_range=(0, 0, 30), max_range=(150, 150, 30))
self.dr.create_texture_comp(
prim_paths=["/World/Floor"], enable_project_uvw=True, texture_list=self.texture_list
self.dr.create_color_comp(prim_paths=["/World/Room"])
def generate_lights(self):
prim_path = omni.kit.utils.get_stage_next_free_path(self.omni_kit.get_stage(), "/World/Env/Light", False)
self.prims.append(prim_path)
prim_path,
"RectLight",
translation=(75, 75, 100),
rotation=(0, 0, 0),
attributes={"height": 150, "width": 150, "intensity": 2000.0, "color": (1.0, 1.0, 1.0)},
def reset(self, shape):
# print(self.prims)
# cmd = omni.kit.builtin.init.DeletePrimsCommand(self.prims)
# cmd.do()
for layer in stage.GetLayerStack():
edit = Sdf.BatchNamespaceEdit()
for path in self.prims:
prim_spec = layer.GetPrimAtPath(path)
if prim_spec is None:
continue
parent_spec = prim_spec.realNameParent
if parent_spec is not None:
edit.Add(path, Sdf.Path.emptyPath)
layer.Apply(edit)
self.prims = []
self.generate_road(shape)
self.dr.randomize_once()
def generate_road(self, shape):
self.tiles, self.state, self.road_map = self.map_generator.generate(shape)
tiles = self.tiles
state = self.state
self.road_path_helper = RoadMapPathHelper(self.road_map)
if tiles.shape != state.shape:
print("tiles and state sizes don't match")
return
stage = self.omni_kit.get_stage()
rows, cols = tiles.shape
self.valid_tiles = []
for x in range(0, rows):
for y in range(0, cols):
if tiles[x, y] != 0:
pos_x = x * self.tile_size[0] + 12.5
pos_y = y * self.tile_size[1] + 12.5
self.create_tile(
stage,
self.tile_usd[tiles[x, y]]["asset"],
Gf.Vec3d(pos_x, pos_y, self.height),
self.direction_map[state[x, y]] + self.tile_usd[tiles[x, y]]["offset"],
# print(paths[x,y])
self.valid_tiles.append([x, y])
def generate_road_from_numpy(self, tiles, state):
self.tiles = tiles
self.state = state
self.road_map = RoadMap.create_from_numpy(self.tiles, self.state)
return
self.create_tile(
stage,
# print(paths[x,y])
def create_tile(self, stage, path, location, rotation):
prefix = "/World/Env/Tiles/Tile"
prim_path = omni.kit.utils.get_stage_next_free_path(stage, prefix, False)
tile_prim = stage.DefinePrim(prim_path, "Xform")
tile_prim.GetReferences().AddReference(path)
xform = UsdGeom.Xformable(tile_prim)
xform_op = xform.AddXformOp(UsdGeom.XformOp.TypeTransform, UsdGeom.XformOp.PrecisionDouble, "")
mat = Gf.Matrix4d().SetTranslate(location)
mat.SetRotateOnly(Gf.Rotation(Gf.Vec3d(0, 0, 1), rotation))
xform_op.Set(mat)
def setup_physics(self):
# Add physics scene
scene = PhysicsSchema.PhysicsScene.Define(stage, Sdf.Path("/World/Env/PhysicsScene"))
# Set gravity vector
scene.CreateGravityAttr().Set(Gf.Vec3f(0.0, 0.0, -981.0))
# Set physics scene to use cpu physics
PhysxSchema.PhysxSceneAPI.Apply(stage.GetPrimAtPath("/World/Env/PhysicsScene"))
physxSceneAPI = PhysxSchema.PhysxSceneAPI.Get(stage, "/World/Env/PhysicsScene")
physxSceneAPI.CreatePhysxSceneEnableCCDAttr(True)
physxSceneAPI.CreatePhysxSceneEnableStabilizationAttr(True)
physxSceneAPI.CreatePhysxSceneEnableGPUDynamicsAttr(False)
physxSceneAPI.CreatePhysxSceneBroadphaseTypeAttr("MBP")
physxSceneAPI.CreatePhysxSceneSolverTypeAttr("TGS")
# Create physics plane for the ground
PhysicsSchemaTools.addGroundPlane(
stage, "/World/Env/GroundPlane", "Z", 100.0, Gf.Vec3f(0, 0, self.height), Gf.Vec3f(1.0)
# Hide the visual geometry
imageable = UsdGeom.Imageable(stage.GetPrimAtPath("/World/Env/GroundPlane/geom"))
if imageable:
imageable.MakeInvisible()
def get_valid_location(self):
if self.tiles is None:
print("cannot provide valid location until road is generated")
return (0, 0)
i = np.random.choice(len(self.valid_tiles), 1)[0]
dist, point = self.road_path_helper.distance_to_path(self.valid_tiles[i])
x, y = point
return (x * self.tile_size[0], y * self.tile_size[1])
# Computes an approximate forward vector based on the current spawn point and nearby valid path point
def get_forward_direction(self, loc):
if self.road_path_helper is not None:
k = 100
dists, pts = self.road_path_helper.get_k_nearest_path_points(np.array([self.get_tile_from_pose(loc)]), k)
pointa = pts[0][0]
pointb = pts[0][k - 1]
if random.choice([False, True]):
pointa, pointb = pointb, pointa
return math.degrees(math.atan2(pointb[1] - pointa[1], pointb[0] - pointa[0]))
# Compute the x,y tile location from the robot pose
def get_tile_from_pose(self, pose):
return (pose[0] / self.tile_size[0], pose[1] / self.tile_size[1])
def distance_to_path(self, robot_pose):
distance, point = self.road_path_helper.distance_to_path(self.get_tile_from_pose(robot_pose))
return distance * self.tile_size[0]
def distance_to_path_in_tiles(self, robot_pose):
return distance
def distance_to_boundary(self, robot_pose):
distance = self.road_path_helper.distance_to_boundary(self.get_tile_from_pose(robot_pose))
def is_inside_path_boundary(self, robot_pose):
return self.road_path_helper.is_inside_path_boundary(self.get_tile_from_pose(robot_pose))
