Errors when running Cartpole RL example in Isaac Sim 2023.1.1
Hi~ I am learning Isaac Gym, and I run the example command following
GitHub - NVIDIA-Omniverse/OmniIsaacGymEnvs: Reinforcement Learning Environments for Omniverse Isaac Gym :
(base) pi@pi:~/.local/share/ov/pkg/OmniIsaacGymEnvs/omniisaacgymenvs$ conda activate rlgpu
(rlgpu) pi@pi:~/.local/share/ov/pkg/OmniIsaacGymEnvs/omniisaacgymenvs$ PYTHON_PATH scripts/rlgames_train.py task=Cartpole
but I got error as:
2024-04-25 08:52:42 [8,386ms] [Error] [omni.kit.app._impl] [py stderr]: Error executing job with overrides: [‘task=Cartpole’]
2024-04-25 08:52:42 [8,533ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2024-04-25 08:52:42 [8,533ms] [Error] [omni.kit.app._impl] [py stderr]: **
2024-04-25 08:52:42 [8,533ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/pi/.local/share/ov/pkg/OmniIsaacGymEnvs/omniisaacgymenvs/scripts/rlgames_train.py”, line 145, in parse_hydra_configs
** task = initialize_task(cfg_dict, env)
I can pass the test for IsaacSim joint_monkey.py
But I can not figure out what cause the Isaac Gym error.
Can anybody give me some suggestion?
My Environment is:
Ubuntu: 20.04
Driver: 525.85.05
Neclus: 2023.2
Cache: 2023.2
Isaac Sim: 2023.1.1
Isaac Gym:
Anaconda:
The console output is attached as an html as:
cartpole_error.zip (7.4 KB)
and the process captured as :
Thank you for your patience and look forward to your advice!
Have you tried running with a smaller num_envs? Other tasks work?
Hi, I’m also having problems running the example, however it works in the Cartpole example, but gives an error when running FrankaCabinet:
Setting seed: 42
Sim params does not have attribute: physx
Sim params does not have attribute: franka
Sim params does not have attribute: cabinet
Sim params does not have attribute: prop
Pipeline: GPU
Pipeline Device: cuda:0
Sim Device: GPU
Task Device: cuda:0
RL device: cuda:0
2024-06-15 08:11:53 [86,941ms] [Warning] [omni.client.plugin] Tick: provider_nucleus: Auth: Failed to create transport: Transport constructor is not found by description
2024-06-15 08:18:46 [500,096ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp – In </World/envs/env_0/franka>: Could not open asset @http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/2023.1.1/Isaac/Robots/Franka/franka_instanceable.usd@ for reference introduced by @anon:0x1c8e2450:World1.usd@</World/envs/env_0/franka>. (recomposing stage on stage @anon:0x1c8e2450:World1.usd@ <0x1af12860>)
2024-06-15 08:18:47 [501,221ms] [Error] [omni.kit.app._impl] [py stderr]: Error executing job with overrides: [‘task=FrankaCabinet’]
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/scripts/rlgames_train.py”, line 145, in parse_hydra_configs
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/utils/task_util.py”, line 105, in initialize_task
env.set_task(
env.set_task(
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/envs/vec_env_rlgames.py”, line 47, in set_task
super().set_task(task, backend, sim_params, init_sim, rendering_dt)
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/exts/omni.isaac.gym/omni/isaac/gym/vec_env/vec_env_base.py”, line 129, in set_task
self._world.reset()
self._world.reset()
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/world/world.py”, line 401, in reset
task.set_up_scene(self.scene)
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/tasks/franka_cabinet.py”, line 67, in set_up_scene
self.get_franka()
self.get_franka()
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/tasks/franka_cabinet.py”, line 128, in get_franka
franka = Franka(prim_path=self.default_zero_env_path + “/franka”, name=“franka”)
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/robots/articulations/franka.py”, line 76, in init
set_drive(
set_drive(
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/tasks/utils/usd_utils.py”, line 79, in set_drive
drive = set_drive_type(prim_path, drive_type)
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/OmniIsaacGymEnvs/omniisaacgymenvs/tasks/utils/usd_utils.py”, line 39, in set_drive_type
drive = UsdPhysics.DriveAPI.Apply(joint_prim, drive_type)
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app.impl] [py stderr]:
2024-06-15 08:18:47 [501,464ms] [Error] [omni.kit.app.impl] [py stderr]: pxr.Tf.ErrorException:
**Error in 'pxrInternal_v0_22__pxrReserved
::UsdPrim::_ApplyAPI’ at line 450 in file /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/prim.cpp : ‘Invalid prim ‘null prim’’**
Error in ‘pxrInternal_v0_22__pxrReserved__::UsdPrim::_ApplyAPI’ at line 450 in file /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/prim.cpp : ‘Invalid prim ‘null prim’’
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
2024-06-15 08:18:47 [501,467ms] [Warning] [carb] [Plugin: omni.spectree.delegate.plugin] Module /home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/exts/omni.usd_resolver/bin/libomni.spectree.delegate.plugin.so remained loaded after unload request
2024-06-15 08:18:47 [501,484ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
2024-06-15 08:18:47 [501,484ms] [Warning] [carb.audio.context] 1 contexts were leaked
2024-06-15 08:18:47 [501,502ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
2024-06-15 08:18:47 [501,508ms] [Warning] [omni.core.ITypeFactory] Module /home/god/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/exts/omni.activity.core/bin/libomni.activity.core.plugin.so remained loaded after unload request.
There was an error running python
I changed numEnvs to 16 and still get the same error, do you know why this is? Appreciate it!
This appears to be an issue with loading the assets. Could you double check that you have access to the asset files on the Nucleus server? You can also try updating to the latest Isaac Sim 4.0 release for the latest asset files.
