Recently I have updated Isaac Sim to version 2023.1.0-hotfix.1 (as seen in this screen from the omniverse launcher)
I also upgraded OmniIsaacGymEnvs by cloning the repo tagged with 2023.1.0b.
Now I’m trying to run locally the training with the task AntSAC as done in the examples.
The script I’m running in the omniisaacgymenvs folder inside the cloned repository is the following (as done here):
PYTHON_PATH scripts/rlgames_train.py task=AntSAC train=AntSAC
For the other task (Ant/Humanoid/Anymal) it works fine but when I try to that task (that uses the SAC instead of PPO, same problem for HumanoidSAC) it gives me an error saying like I missed some configuration in the command. The error rises after the first step in the simulation, after loading Isaac Sim.
[2023-11-23 10:27:52] Running RL reset
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: Error executing job with overrides: ['task=HumanoidSAC', 'train=HumanoidSAC']
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/Documents/OmniIsaacGymEnvs23/omniisaacgymenvs/scripts/rlgames_train.py", line 150, in <module>
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: parse_hydra_configs()
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/main.py", line 94, in decorated_main
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: _run_hydra(
_run_hydra(
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/_internal/utils.py", line 394, in _run_hydra
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: _run_app(
_run_app(
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/_internal/utils.py", line 457, in _run_app
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: run_and_report(
run_and_report(
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/_internal/utils.py", line 223, in run_and_report
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: raise ex
raise ex
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/_internal/utils.py", line 220, in run_and_report
2023-11-23 09:27:58 [19,592ms] [Error] [omni.kit.app._impl] [py stderr]: return func()
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]:
return func()
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/_internal/utils.py", line 458, in <lambda>
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: lambda: hydra.run(
lambda: hydra.run(
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/_internal/hydra.py", line 132, in run
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: _ = ret.return_value
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/core/utils.py", line 260, in return_value
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: raise self._return_value
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/hydra/core/utils.py", line 186, in run_job
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: ret.return_value = task_function(task_cfg)
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/Documents/OmniIsaacGymEnvs23/omniisaacgymenvs/scripts/rlgames_train.py", line 142, in parse_hydra_configs
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: rlg_trainer.run()
rlg_trainer.run()
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/Documents/OmniIsaacGymEnvs23/omniisaacgymenvs/scripts/rlgames_train.py", line 74, in run
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: runner.run(
runner.run(
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/rl_games/torch_runner.py", line 133, in run
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: self.run_train(args)
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/rl_games/torch_runner.py", line 116, in run_train
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: agent.train()
agent.train()
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/rl_games/algos_torch/sac_agent.py", line 541, in train
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: step_time, play_time, update_time, epoch_total_time, actor_losses, entropies, alphas, alpha_losses, critic1_losses, critic2_losses = self.train_epoch()
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/rl_games/algos_torch/sac_agent.py", line 529, in train_epoch
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: return self.play_steps(random_exploration)
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: File "/home/eliatosin/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/rl_games/algos_torch/sac_agent.py", line 497, in play_steps
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: self.obs = next_obs.clone()
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: AttributeError
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: :
2023-11-23 09:27:58 [19,593ms] [Error] [omni.kit.app._impl] [py stderr]: 'dict' object has no attribute 'clone'
AttributeError: 'dict' object has no attribute 'clone'
(the folder /home/eliatosin/Documents/OmniIsaacGymEnvs23 is actually the cloned repository OmniIsaacGymEnvs. I renamed it to know the version.
Thank you
