Is there any way to get which airflow this product number has ? P2C or C2P ?
Q9E63A, is not a Mellanox part number so i am assuming you are referring to the “HPE StoreFabric SN2010M 25GbE 18SFP28 4QSFP28 Switch”.
If this is indeed the case, then you can see the below link to match HPE to Mellanox part numbers:
http://www.mellanox.com/related-docs/oem/hpe/Mellanox-and-HPE-OEM-Ethernet-Guide.pdf
HPE Q9E63A corresponds to Mellanox MSN2010-CB2F which is of P2C airflow.
When you look at Mellanox Part Numbers, the letter after the digit 2 means the airflow F = P2C and R= C2P.
Hope this helps.
