Hi
I’m wondering why this firmware version is not in the regular Linux Firmware archive?
SN2010
13.2010.4026
‘Index of /firmware’ → 3146 latest
Hi
SN2010
13.2010.4026
That firmware appears to be very new, where are you seeing references to it?
mlxfwmanager --query
Querying Mellanox devices firmware …
Device Type: Spectrum
Part Number: Q9E63-63001_Ax
Description: HPE StoreFabric SN2010M 25GbE 18SFP28 4QSFP28 Half Width Switch
PSID: HPE0000000025
PCI Device Name: 0000:01:00.0
Base MAC: 98039bfde580
Versions: Current Available
FW 13.2010.4026 N/A
Part Number: MSN2010-Cxxx_Ax
Description: Spectrum™ based 10GbE/100GbE 1U Open Ethernet switch with MLNX-OS; 18 SFP28 ports; 4 QSFP28 ports; 2 power supplies (AC); x86 dual core; Short depth; P2C airflow; Rail Kit; RoHS6
PSID: MT_0000000108
Base MAC: 1c34da964a40
FW 13.2010.4026 N/A
The firmware you’re looking at should be bundled with the OS that was installed on the switch and is not expected to be independently downloadable. If you are running SwitchDev, you should run the firmware noted in the release notes for your kernel version:
The wiki release notes seem to mention very old firmware versions. Oh well, everything seems fine with the newer firmware.
