audigo
#1
I have just bought a SX1012 that is being setup for large image transfers over Ethernet. The setup
appears to go through without any errors which was done several times. I can access with serial or
ssh however both http port 80 and https 433 are available and come back with errors:
The page isn’t redirecting properly
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
Same happens with any browser from any internal workstation.
This is the “web” setup on mgmt0
mellanox-2 [standalone: master] # show web
Web User Interface:
Web interface enabled: yes
HTTP enabled: yes
HTTP port: 80
HTTP redirect to HTTPS: no
HTTPS enabled: yes
HTTPS port: 443
HTTPS certificate name: default-cert
Listen enabled: yes
No Listen Interfaces.
Inactivity timeout: 1 hr
Session timeout: 2 hr 30 min
Session renewal: 30 min
Web file transfer proxy:
Proxy enabled: no
Web file transfer certificate authority:
HTTPS server cert verify: yes
HTTPS supplemental CA list: default-ca-list
I have multiple enterprise devices like switches that work fine from port 80 or port 443 on the
same test workstation.
Thank you
Paul
yairi
#2
Hi Daniel, Open a ticket with Mellanox support. They can probably provide you with the version image. (support@mellanox.com mailto:support@mellanox.com )
P.S. A support contract for your equipment should not be very costly. you should consider.
Hello Paul
What revision of code are you running on the switch?
eddies
#4
Hi Paul,
AFAIK this issue is fixed in newer versions of the MLNX-OS software. what is the MLNX-OS code running (“show version concise”)?
Hello Steve,
I bought this switch from Paul on Ebay to build a small private renderfarm for VR
and photogrammetry (for students and IT enthusiasts).
I can ping the MGMT Port but the browser (MS-IE11) can‘t open the WebUI page.
The software revision is:
U-Boot 2009.01 SX_PPC_M460EX SX_3.2.0330-82 ppc (Dec 20 2012 - 17:53:54)
Default image: ‘SX_PPC_M460EX SX_3.3.5006 2014-05-20 12:19:44 ppc’
Is there a possibillity to get an MLNX-OS update for this switch?
Thank you!
Daniel
Hello Yairi,
thanks for your answer. I got the update Image files from Mellanox.
Procedure was, install first “image-PPC_M460EX-SX_3.4.0012.img 2014-12-15”
after this update the WebUI was working.
2nd update was “image-PPC_M460EX-3.4.2008.img 2015-06-12”
3rd update “image-PPC_M460EX-3.5.1006.img 2016-03-09”
and 4th was “image-PPC_M460EX-3.6.1002.img 2016-06-09”
I installed all updates in CLI mode from a USB stick. But not all USB sticks are good for this.
Only an old USB 2.0 4GB stick Fat32 formatted was working.
