SN2010 initial configuration issues
Hi there trying to get a bit of support, I have a SN2010 switch and after configuring the initial setup and during the switch up I entered the static address but the switch says that it doesn’t match the gateway ip. I try dhcp but the switch doesn’t get an address. So I’m not able to get into the web UI to configure the rest of it. I’ve rerun the initial setup and am unable to connect to the switch through the web UI.
Hi Anthony,
I would begin here to make sure the mgmt0 is being configured properly:
https://community.mellanox.com/s/article/howto-get-started-with-mellanox-switches
You can start the configuration wizard by running the following:
(config) # configuration jump-start
Once you go through the wizard and get the basic parameters configured and you’re in the CLI, do a “show interfaces mgmt0” to ensure you have a link and to verify the configured IP address:
SN2100 [standalone: master] (config) # show interfaces mgmt0
Interface mgmt0 status:
Comment :
Admin up : yes
Link up : yes
DHCP running : yes
IP address : 10.10.10.100
Netmask : 255.255.255.0
IPv6 enabled : yes
Autoconf enabled: no
Autoconf route : yes
Autoconf privacy: no
DHCPv6 running : yes (but no valid lease)
IPv6 addresses : 1
IPv6 address:
fe80::9a03:9bff:feae:4dd8/64
Speed : 1000Mb/s (auto)
Duplex : full (auto)
Interface type : ethernet
Interface source: bridge
MTU : 1500
HW address : 98:03:9B:AE:4D:D8
Rx:
622758443 bytes
3160136 packets
0 mcast packets
0 discards
0 errors
0 overruns
0 frame
Tx:
236829813 bytes
518354 packets
0 discards
0 errors
0 overruns
0 carrier
0 collisions
1000 queue len
If there is link and a configured IP address:
-Are you able to ping the IP?
-If you can ping, can you SSH to the mgmt0?
-If you can SSH, try a different browser or PC on the same subnet
-Try using https
If you are still having problems, please contact Mellanox Technical Support.
Thanks,
Kevin
