mellanox u-boot command prompt password
What is the password to get into my switch u-boot command prompt???
U-Boot 2009.01 SX_PPC_M460EX SX_3.2.0330-82 ppc (Dec 20 2012 - 17:53:54)
CPU: AMCC PowerPC 460EX Rev. B at 1000 MHz (PLB=166, OPB=83, EBC=83 MHz)
Security/Kasumi support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
Internal PCI arbiter disabled
32 kB I-Cache 32 kB D-Cache
Board: Mellanox PPC460EX Board
FDEF: No
I2C: ready
DRAM: 2 GB (ECC enabled, 333 MHz, CL3)
FLASH: 16 MB
NAND: 1024 MiB
PCI: Bus Dev VenId DevId Class Int
PCIE0: link is not up.
PCIE1: successfully set as root-complex
01 00 15b3 c738 0c06 00
Net: ppc_4xx_eth0, ppc_4xx_eth1
Reading image settings from EEPROM
Mellanox MLNX-OS
Default image: ‘SX_PPC_M460EX SX_3.3.4304 2014-01-14 20:31:55 ppc’
Press Enter to boot this image, or ‘Ctrl B’ for boot menu
Booting default image in: 0
Mellanox MLNX-OS Boot Menu:
  • 1: SX_PPC_M460EX SX_3.3.4304 2014-01-14 20:31:55 ppc
2: PPC_M460EX 3.4.3002 2015-07-30 20:13:15 ppc
u: USB menu (if USB device connected) (password required)
c: Command prompt (password required)
Choice:
Enter Password:
Thanks !
Hi Matrix Lee,
I don’t really think you need it.
Why do you thing you need it for?
After I reimage the switch, there is flash green light of the system status(does not change to solid green after boot into OS ). I am trying to get into the u-boot command prompt to see if I can recover the fault.
no matter what is the issue - uboot won’t help.
Can you provide more details what exactly you did?
how did you re image?
You’ve installed 3.3.4304 or 3.4.3002
I see you are getting Console prompt so where the switch getting an issue?
Hi Lee,
Let me know if it’s still relevent as I saw you opened a ticket ( I believe it’s you as it’s the same questions) with our support team.
Thank you for following up, I have contacted the Mellanox support team. They suggested me upgrading the mlnx-os with intermediate versions prior to upgrading to the latest.
I am trying this out. Hopefully this can solve the problem.
Did the down grade to 3.2.0330-100 last night, the management module still not detected. Will try the next version of 3.3.4100 today.
