Hi Guys,
I just got a SX6036 from others. The seller told me he has reset everything. This means username/pwd has been reset to admin.
But When I try to boot it, I find it can’t boot due to no space left.
The following is my full log to try to access it. But no works.
Can anyone give advice?
CPU: AMCC PowerPC 460EX Rev. B at 1000 MHz (PLB=166, OPB=83, EBC=83 MHz)
Security/Kasumi support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
Internal PCI arbiter disabled
32 kB I-Cache 32 kB D-Cache
Board: Mellanox PPC460EX Board
FDEF: No
I2C: ready
DRAM: 2 GB (ECC enabled, 333 MHz, CL3)
FLASH: 16 MB
NAND: 1024 MiB
PCI: Bus Dev VenId DevId Class Int
PCIE0: link is not up.
PCIE1: successfully set as root-complex
01 00 15b3 c738 0c06 00
Net: ppc_4xx_eth0, ppc_4xx_eth1
Reading image settings from EEPROM
Mellanox MLNX-OS
Default image: 'PPC_M460EX 3.5.1006 2016-03-09 11:29:49 ppc'
Press Enter to boot this image, or 'Ctrl B' for boot menu
Booting default image in: 0
Booting location 1: 'PPC_M460EX 3.5.1006 2016-03-09 11:29:49 ppc'
INIT: version 2.86 booting
Starting: PPC_M460EX 3.5.1006 2016-03-09 11:29:49 ppc
Starting udev: [ OK ]
Setting clock (utc): Tue Oct 15 19:07:14 UTC 2019 [ OK ]
Setting hostname localhost: [ OK ]
Checking filesystems
Checking all file systems.
[ OK ]
Remounting root filesystem in read-write mode: [ OK ]
^B
mount: /: filesystem mounted, but mount(8) failed: No space left on device
Mounting local filesystems: mount: /config: filesystem mounted, but mount(8) failed: No space left on device
mount: /var: filesystem mounted, but mount(8) failed: No space left on device
mount: /dev/shm: filesystem mounted, but mount(8) failed: No space left on device
mount: devpts is already mounted or /dev/pts busy
mount: sysfs is already mounted or /sys busy
mount: proc is already mounted or /proc busy
[FAILED]
Running vpart script: [ OK ]
Applying file system skeletons: base_var base_config .
mount: /vtmp: filesystem mounted, but mount(8) failed: No space left on device
rm: cannot remove '/var/run/dhclient-mgmt1.pid': Input/output error
rm: cannot remove '/var/run/httpd.pid': Input/output error
rm: cannot remove '/var/run/klogd.pid': Input/output error
rm: cannot remove '/var/run/mDNSResponder.pid': Input/output error
rm: cannot remove '/var/run/pm.pid': Input/output error
rm: cannot remove '/var/run/sshd.pid': Input/output error
INIT: Entering runlevel: 3
Starting system services
Starting sx_low_level_if: Starting sx_low_level_if:
Loading i2c_mux_pca954x - Success
Loading sx_glue_if - Success
Loading watchdog - Success
Loading cpld_handler - Success
Loading mellaggra_mod - Success
Loading switchx - Success
[ OK ]
Starting openibd: IPoIB configuration for embedded system
Loading SX driver:[ OK ]
Loading HCA driver and Access Layer:[ OK ]
Setting up InfiniBand network interfaces:
Setting up service network . . .[ done ]
Reloading udev:
[ OK ]
Starting system logger: [ OK ]
Starting kernel logger: [ OK ]
touch: cannot touch '/var/lock/subsys/syslog': Input/output error
Starting fips_post: [ OK ]
Running renaming interfaces
Renaming: MAC: 24:8A:07:58:FE:9C ifindex: 2 name: mgmt0
Renaming: MAC: 24:8A:07:58:FE:9D ifindex: 3 name: mgmt1
touch: cannot touch '/var/lock/subsys/rename_ifs': Input/output error
Checking for unexpected shutdown
Detected unexpected shutdown!touch: cannot touch '/var/opt/tms/.detected_unexpected_shutdown': Input/output error
touch: setting times of '/var/opt/tms/.unexpected_shutdown': Input/output error
touch: cannot touch '/var/lock/subsys/shutdown_check': Input/output error
Probing for HRNG module
Starting rngd: [ OK ]
Running system image: PPC_M460EX 3.5.1006 2016-03-09 11:29:49 ppc
Applying initial configuration: Oct 15 19:10:13 INFO LOG: Initializing SX log with STDOUT as output file.
touch: cannot touch '/tmp/ee.conf.3174': No space left on device
chmod: cannot access '/tmp/ee.conf.3174': No such file or directory
/sUnable to handle kernel paging request for data at address 0x00000024
biFaulting instruction address: 0xc011f6b4
n/Oops: Kernel access of bad area, sig: 11 [#1]
PREEMPT mlnx460ex
Modules linked in: ip6table_filter ip6_tables iptable_filter ip_tables x_tables ib_ipoib(O) ib_cm(O) ib_sa(O) inet_lro ib_uverbs(O) ib_umad(O) sx_ib(O) ib_mad(O) ib_core(O) ib_addr(O) ipv6 compat(O) sx_netdev(O) sx_core(O) 8021q switchx(O) mellaggra_mod(O) cpld_handler(O) watchdog(O) sx_glue_if(O) i2c_mux_pca954x i2c_mux ehci_hcd usbcore lm87 hwmon_vid hwmon usb_common unix
CPU: 0 PID: 3223 Comm: sync Tainted: G O 3.10.27-MELLANOXuni-m460ex PPC_M460EX
task: ef8e5a40 ti: ee96a000 task.ti: ee96a000
NIP: c011f6b4 LR: c01203c8 CTR: c011ec70
REGS: ee96bda0 TRAP: 0300 Tainted: G O (3.10.27-MELLANOXuni-m460ex)
MSR: 00029000 <CE,EE,ME> CR: 24000024 XER: 20000006
DEAR: 00000024, ESR: 00000000
GPR00: c01203c8 ee96be50 ef8e5a40 eec95600 f904ee34 ee96beb8 ee96bec8 000200da
GPR08: 00000001 00000000 ffff0001 ee96bee0 24000022 1001d7c4 00000000 00000000
GPR16: 100fda60 100fdac0 1016be10 00000000 00000000 100e0000 00000000 100e0000
GPR24: 1016be00 ee96a000 ee96bf2c c00d2ca4 00000001 eec95720 f904ee34 eec95600
NIP [c011f6b4] __jffs2_flush_wbuf+0x78/0xbd4
LR [c01203c8] jffs2_flush_wbuf_pad+0x3c/0x6c
Call Trace(ef8e5a40): name=sync, state=0
[ee96be50] [00000002] 0x2 (unreliable)
[ee96bec0] [c01203c8] jffs2_flush_wbuf_pad+0x3c/0x6c
[ee96bee0] [c011eca0] jffs2_sync_fs+0x30/0x44
[ee96bef0] [c00ae694] iterate_supers+0x9c/0x110
[ee96bf20] [c00d2de4] sys_sync+0x54/0xa0
[ee96bf40] [c000ae74] ret_from_syscall+0x0/0x3c
--- Exception: c01 at 0xff58f40
LR = 0x10000cc0
Instruction dump:
3ac00000 2f890000 41be0b70 81230058 7c9c2378 83c30114 7fde4b96 81230078
1fde0034 7fc9f214 8123007c 7fc4f378 <80a90024> 38a50001 4bff5935 2f830000
---[ end trace b1aa54a97408b924 ]---
aiset.sh: line 289: /tmp/ee.conf.3174: No space left on device
-E- Failed to open file /tmp/ee.conf.3174: No such file or directory/sbin/aiset.sh: line 68: 3223 Segmentation fault sync
Xshell 7 (Build 0157).txt (36.2 KB)
