I had saved a portion the end of the output and then attempting to boot a second time at the bottom:
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Creating 9 MTD partitions on “4cc000000.nor_flash”:
0x00000000-0x001e0000 : “kernel”
0x001e0000-0x00200000 : “dtb”
0x00200000-0x01dc0000 : “ramdisk”
0x01dc0000-0x01fa0000 : “safe-kernel”
0x01fa0000-0x01fc0000 : “safe-dtb”
0x01fc0000-0x03b80000 : “safe-ramdisk”
0x03b80000-0x03f60000 : “config”
0x03f60000-0x03fa0000 : “u-boot env”
0x03fa0000-0x04000000 : “u-boot”
NAND device: Manufacturer ID: 0x20, Chip ID: 0xda (ST Micro NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 1 MTD partitions on “4e0000000.ndfc.nand”:
0x00000000-0x10000000 : “log”
i2c /dev entries driver
IBM IIC driver v2.1
ibm-iic(): using standard (100 kHz) mode
i2c-2: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 0)
i2c-3: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 1)
i2c-4: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 2)
i2c-5: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 3)
rtc-ds1307 6-0068: rtc core: registered ds1338 as rtc0
rtc-ds1307 6-0068: 56 bytes nvram
i2c-6: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 4)
i2c-7: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 5)
i2c-8: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 6)
i2c-9: Virtual I2C bus (Physical bus i2c-0, multiplexer 0x70 port 7)
pca954x 0-0070: registered 8 virtual busses for I2C switch pca9548
TCP cubic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
rtc-ds1307 6-0068: setting system clock to 2000-01-18 01:06:09 UTC (948157569)
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 172k init
init started: BusyBox v1.12.2 (2011-01-03 14:13:22 IST)
starting pid 15, tty ‘’: ‘/etc/rc.d/rcS’
mount: no /proc/mounts
Mounting /proc and /sys
Mounting filesystems
Loading module Voltaire
Empty flash at 0x0cdcf08c ends at 0x0cdcf800
Starting crond:
Starting telnetd:
ibsw-init.sh start…
Tue Jan 18 01:06:42 UTC 2000
INSTALL FLAG 0x0
starting syslogd & klogd …
Starting ISR: Unable to handle kernel paging request for data at address 0x0000001e
Faulting instruction address: 0xc00ec934
Oops: Kernel access of bad area, sig: 11 [#1]
Voltaire
Modules linked in: ib_is4(+) ib_umad ib_sa ib_mad ib_core memtrack Voltaire
NIP: c00ec934 LR: c00ec930 CTR: 00000000
REGS: d7bdfd10 TRAP: 0300 Not tainted (2.6.26)
MSR: 00029000 <EE,ME> CR: 24000042 XER: 20000000
DEAR: 0000001e, ESR: 00000000
TASK = d7b9c800[49] ‘jffs2_gcd_mtd9’ THREAD: d7bde000
GPR00: 00000001 d7bdfdc0 d7b9c800 00000000 000000d0 00000003 df823040 0000007f
GPR08: 22396d59 d9743920 c022de58 00000000 24000024 102004bc c026b9a0 c026b910
GPR16: c026b954 c026b630 c026b694 c022b790 d8938150 d8301000 c022b758 d7bdfe30
GPR24: 00000000 0000037c d8301400 00000abf d9743d80 00000000 d8938158 df823000
NIP [c00ec934] jffs2_get_inode_nodes+0xb6c/0x1020
LR [c00ec930] jffs2_get_inode_nodes+0xb68/0x1020
Call Trace:
[d7bdfdc0] [c00ec758] jffs2_get_inode_nodes+0x990/0x1020 (unreliable)
[d7bdfe20] [c00ece28] jffs2_do_read_inode_internal+0x40/0x9e8
[d7bdfe90] [c00ed838] jffs2_do_crccheck_inode+0x68/0xa4
[d7bdff00] [c00f1ed8] jffs2_garbage_collect_pass+0x160/0x664
[d7bdff50] [c00f36c8] jffs2_garbage_collect_thread+0xf0/0x118
[d7bdfff0] [c000bdb8] kernel_thread+0x44/0x60
Instruction dump:
7f805840 409c000c 801d0004 48000008 801d0008 2f800000 409effdc 2f9d0000
40be0010 48000180 4802ba05 7c7d1b78 7fa3eb78 2f800000 409effec
—[ end trace b57e19dd3d61c6af ]—
ib_is4 0000:81:00.0: ep0_dev_name 0000:81:00.0
Unable to handle kernel paging request for data at address 0x00000034
Faulting instruction address: 0xc002f3b0
Oops: Kernel access of bad area, sig: 11 [#2]
Voltaire
Modules linked in: is4_cmd_driver ib_is4 ib_umad ib_sa ib_mad ib_core memtrack Voltaire
NIP: c002f3b0 LR: c002fb00 CTR: c00f3a10
REGS: df8a3de0 TRAP: 0300 Tainted: G D (2.6.26)
MSR: 00021000 CR: 24544e88 XER: 20000000
DEAR: 00000034, ESR: 00000000
TASK = df88e800[8] ‘pdflush’ THREAD: df8a2000
GPR00: c002fb00 df8a3e90 df88e800 00000001 d7b9c800 d7b9c800 00000000 00000001
GPR08: 00000001 00000000 24544e22 00000002 00004b1a 67cfb19f 1ffef400 00000000
GPR16: 1ffe42d8 00000000 1ffebfa4 00000000 00000000 00000004 c0038778 c0261ac4
GPR24: 00000001 c02f0000 00000000 d7b9c800 00000001 d7b9c800 00000000 d8301400
NIP [c002f3b0] prepare_signal+0x1c/0x1a4
LR [c002fb00] send_signal+0x28/0x214
Call Trace:
[df8a3e90] [c0021bb8] check_preempt_wakeup+0xd8/0x110 (unreliable)
[df8a3eb0] [c002fb00] send_signal+0x28/0x214
[df8a3ed0] [c002fe40] send_sig_info+0x28/0x48
[df8a3ef0] [c00f35c4] jffs2_garbage_collect_trigger+0x3c/0x50
[df8a3f00] [c00f3a40] jffs2_write_super+0x30/0x5c
[df8a3f10] [c007340c] sync_supers+0x80/0xd0
[df8a3f30] [c0054dc8] wb_kupdate+0x48/0x150
[df8a3f90] [c0055434] pdflush+0x104/0x1a4
[df8a3fe0] [c00387c4] kthread+0x4c/0x88
[df8a3ff0] [c000bdb8] kernel_thread+0x44/0x60
Instruction dump:
80010034 bb810020 7c0803a6 38210030 4e800020 9421ffe0 7c0802a6 bf810010
90010024 7c9d2378 83c4034c 7c7c1b78 <801e0034> 70090008 40820100 2f83001f
------------[ cut here ]------------
Badness at kernel/exit.c:965
NIP: c00273f0 LR: c000a03c CTR: c013b2b4
REGS: df8a3cb0 TRAP: 0700 Tainted: G D (2.6.26)
MSR: 00021000 CR: 24544e22 XER: 20000000
GPR00: 00000001 df8a3d60 df88e800 0000000b 00002d73 ffffffff c013e13c c02eb620
GPR08: 00000001 00000001 00002d73 00000000 24544e84 67cfb19f 1ffef400 00000000
GPR24: 00000001 c02f0000 00000000 d7b9c800 df8a3de0 0000000b df88e800 0000000b
NIP [c00273f0] do_exit+0x24/0x5ac
LR [c000a03c] kernel_bad_stack+0x0/0x4c
Call Trace:
[df8a3d60] [00002d41] 0x2d41 (unreliable)
[df8a3da0] [c000a03c] kernel_bad_stack+0x0/0x4c
[df8a3dc0] [c000ef90] bad_page_fault+0xb8/0xcc
[df8a3dd0] [c000c4c8] handle_page_fault+0x7c/0x80
Instruction dump:
bb61000c 38210020 4e800020 9421ffc0 7c0802a6 bf010020 90010044 7c7f1b78
7c5e1378 800203e0 3160ffff 7d2b0110 <0f090000> 54290024 8009000c 5409012f
U-Boot 1.3.4.32 (Feb 6 2011 - 10:18:30)
CPU: AMCC PowerPC 460EX Rev. B at 666.666 MHz (PLB=166, OPB=83, EBC=83 MHz)
Security/Kasumi support
Bootstrap Option E - Boot ROM Location EBC (16 bits)
Internal PCI arbiter disabled
32 kB I-Cache 32 kB D-Cache
Board: 4036QDR - Voltaire 4036 QDR Switch Board
I2C: ready
DRAM: 512 MB (ECC enabled, 333 MHz, CL3)
FLASH: 64 MB
NAND: 256 MiB
*** Warning - bad CRC, using default environment
MAC Address: 00:08:F1:20:52:E8
PCIE1: successfully set as root-complex
PCIE: Bus Dev VenId DevId Class Int
01 00 15b3 bd34 0c06 00
Net: ppc_4xx_eth0
Type run flash_nfs to mount root filesystem over NFS
Hit any key to stop autoboot: 0
=> run flash_nfs
Booting kernel from Legacy Image at fc000000 …
Image Name: Linux-2.6.26
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 1406000 Bytes = 1.3 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
Uncompressing Kernel Image … OK
