i have two SX6018 switches: one boots just fine, second one stops in a different mode: Switch-B(4)> and MLNX-OS commands are not available. Could anyone help me to figure out what is wrong? How to boot into normal MLNX-OS mode?
Thank you in advance!
Here are the logs from good and bad switches:
GOOD switch:
U-Boot 2009.01 SX_PPC_M460EX SX_3.2.0330-82 ppc (Dec 20 2012 - 17:53:54)
CPU: AMCC PowerPC 460EX Rev. B at 1000 MHz (PLB=166, OPB=83, EBC=83 MHz)
Security/Kasumi support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
Internal PCI arbiter disabled
32 kB I-Cache 32 kB D-Cache
Board: Mellanox PPC460EX Board
FDEF: No
I2C: ready
DRAM: Auto calibration -/
FDEF: No
I2C: ready
DRAM: 2 GB (ECC enabled, 333 MHz, CL3)
FLASH: 16 MB
NAND: 1024 MiB
PCI: Bus Dev VenId DevId Class Int
PCIE0: link is not up.
PCIE1: successfully set as root-complex
01 00 15b3 c738 0c06 00
Net: ppc_4xx_eth0, ppc_4xx_eth1
Reading image settings from EEPROM
Mellanox MLNX-OS
Default image: ‘SX_PPC_M460EX SX_3.3.3000 2013-02-26 21:57:35 ppc’
Press Enter to boot this image, or ‘Ctrl B’ for boot menu
Booting default image in: 0
Booting location 1: ‘SX_PPC_M460EX SX_3.3.3000 2013-02-26 21:57:35 ppc’
INIT: version 2.86 booting
Starting: SX_PPC_M460EX SX_3.3.3000 2013-02-26 21:57:35 ppc
Starting udev: [ OK ]
Setting clock (utc): Tue Oct 21 15:15:25 UTC 2014 [ OK ]
Setting hostname localhost: [ OK ]
Checking filesystems
Checking all file systems.
[ OK ]
Remounting root filesystem in read-write mode: [ OK ]
Mounting local filesystems: [ OK ]
Running vpart script: [ OK ]
Applying file system skeletons: base_var base_config .
Enabling /etc/fstab swaps: [ OK ]
INIT: Entering runlevel: 3
Starting system services
Starting sx_low_level_if: Starting sx_low_level_if:
Loading glue logic low level - Success
Loading mellaggra module - Success
Loading cpld handler - Success
Loading sx i2c module - Success
[ OK ]
Starting openibd: IPoIB configuration for embedded system
Loading SX driver:[ OK ]
Loading Extended Port 0 driver and Access Layer:[ OK ]
Setting up InfiniBand network interfaces:
Setting up service network . . .[ done ]
Reloading udev:
[ OK ]
Starting system logger: [ OK ]
Starting kernel logger: [ OK ]
Running renaming interfaces
Renaming: MAC: 00:02:C9:63:8E:5A ifindex: 2 name: mgmt0
Renaming: MAC: 00:02:C9:63:8E:5B ifindex: 3 name: mgmt1
Checking for unexpected shutdown
Probing for HRNG module
Starting rngd: [ OK ]
Running system image: SX_PPC_M460EX SX_3.3.3000 2013-02-26 21:57:35 ppc
Applying initial configuration:
Starting internal_startup: [ OK ]
Starting clean_issnvram: Deleting issnvram.txt
[ OK ]
Starting intr_hndl: Starting :
Loading int handler module - Success
[ OK ]
Starting iss-nvram-mac: [ OK ]
Starting sx_pra: Starting proxy arp management:
Loading proxy arp management module - Success
[ OK ]
Starting udevd: Reloading udev…
[ OK ]
Starting pm: [ OK ]
Starting oops_dump_reg: Starting kernel reg dump:
Loading kernel reg dump module - Success
[ OK ]
Starting mst: Starting MST (Mellanox Software Tools) driver set
Loading MST PCI module - Success
Loading MST PCI configuration module - Success
Create devices
[ OK ]
Mellanox MLNX-OS Switch Management
switch-638e5a login: admin
Password:
Last login: Tue Oct 21 14:32:51 on ttyS0
Mellanox Switch
lines 1-23
System is initializing!
This may take a few minutes
Modules are being configured
switch-638e5a [standalone: master] > en
switch-638e5a [standalone: master] # ?
aaa Configure Authentication, Authorization, and
Accounting
boot Configure system boot parameters
clear Reset certain statistics or clear caches
cli Configure CLI shell options
configure Enter configuration mode
crypto Configure cryptographic settings
debug Debugging commands
disable Leave enable mode
lines 18-40/40 (END)
