Mellanox 100GbE cable to high tech global qsfp28 cage
Hello
I have the following parts :
  1. "high tech global " 100GbE qsfp28 cage
http://www.hitechglobal.com/FMCModules/FMC_X4QSFP28.htm
  1. and wanto to connect it to the connectX5 mellanox card
https://www.mellanox.com/sites/default/files/related-docs/prod_adapter_cards/PB_ConnectX-5_EN_Card.pdf
  1. I want to use the following cable
https://www.mellanox.com/related-docs/prod_cables/PB_MCP1600-Cxxx_100GbE_QSFP28_DAC.pdf
So ,
mellanox100gbe card <–> mellanox 100gbe cable <–> high tech global qsf28 cage
From High Tech Global qsfp28 cage schematic we see that we need to drive the following ports
LPMode
IntL
ModPrsL
ModselL
RESET_N
Seems to be a standard of qsfp28
Can someone refer me to relevant documentation or explain me with values those ports should receive ? in order to interface it to the mellanox cable / card previously described
Thank you very much
Shal
Hello Shal,
Thank you for posting your inquiry on the Mellanox Community.
Based on the information provided and the specifics you are requesting, we recommend to reach out to the vendor of the cage you are using regarding the info you need.
Thank you,
~Mellanox Technical Support
OK thank you very much
