This is a follow up post from Secureboot on Nano.
Thanks to your support,
now I can successfully flash an image enabled Secureboot, but in which a system.img is rebuilt even with an option -r.
Thus, we can not burn our own image (APP) for our product.
Please let us know an option to achieve this.
There is a README for mass flash:
nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/README_Massflash.txt
Please take a look. you should be able to do mass flash by following the steps.
Thanks. I have never realized this exists.
I will try this, but with this method, the pre-built image is not replaced with the default one, right?
I followed the guide and confirmed -r option did work, but ended up with an error Error: </partition> does not exist.. What does this error mean?
$ sudo ./nvmassflashgen.sh -x 0x21 -y PKC -u ../emi_pkc.pem -r jetson-nano-emmc mmcblk0p1
|| Generate Massflash Image in the master host: ||
|| Requires the Jetson connected in RCM mode. ||
1 Jetson devices in RCM mode. USB: 3-9
| Step 1: Generate Command File
# L4T BSP Information:
# R32 , REVISION: 3.1
Board ID() version()
copying bctfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a00.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a00.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Existing tbcfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a00.dtb)... done.
copying cfgfile(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml... done.
copying flasher(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --cfg flash.xml --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a00.dtb.signed --applet nvtboot_recovery.bin --cmd "sign" --chip 0x21 --key /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0110 ] tegrasign --key /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem --getmode mode.txt
[ 0.0125 ] PKC key in Open SSL format
[ 0.0129 ] Key size is 256 bytes
[ 0.0171 ]
[ 0.0824 ] Generating RCM messages
[ 0.0843 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0863 ] RCM 0 is saved as rcm_0.rcm
[ 0.0873 ] RCM 1 is saved as rcm_1.rcm
[ 0.0876 ] List of rcm files are saved in rcm_list.xml
[ 0.0876 ]
[ 0.0876 ] Signing RCM messages
[ 0.0896 ] tegrasign --key /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0916 ] PKC key in Open SSL format
[ 0.0921 ] Key size is 256 bytes
[ 0.0924 ] Saving public key in pub_key.key
[ 0.2958 ] Saving public key Hash as binary: pub_key.hash
[ 0.2958 ] Saving public key Hash as big-endian text: pub_key.hash_txt
[ 0.2958 ] Saving public key Hash as little-endian(sysfs) text: pub_key.hash_sysfs_txt
[ 0.2958 ]
[ 0.2959 ] Copying signature to RCM mesages
[ 0.2978 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[ 0.3006 ]
[ 0.3007 ] Parsing partition layout
[ 0.4029 ] tegraparser --pt flash.xml.tmp
[ 0.4057 ]
[ 0.4058 ] Creating list of images to be signed
[ 0.4178 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.4312 ]
[ 0.4312 ] Generating signatures
[ 0.4330 ] tegrasign --key /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem --list images_list.xml --pubkeyhash pub_key.key
[ 0.4350 ] PKC key in Open SSL format
[ 0.4355 ] Key size is 256 bytes
[ 0.4358 ] Saving public key in pub_key.key
[ 1.7701 ] Saving public key Hash as binary: pub_key.hash
[ 1.7701 ] Saving public key Hash as big-endian text: pub_key.hash_txt
[ 1.7701 ] Saving public key Hash as little-endian(sysfs) text: pub_key.hash_sysfs_txt
[ 1.7701 ]
[ 1.7701 ] Generating br-bct
[ 1.7952 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 1.7970 ] Copying Sdram info from 0 to 1 set
[ 1.8012 ] Copying Sdram info from 1 to 2 set
[ 1.8012 ] Copying Sdram info from 2 to 3 set
[ 1.8012 ]
[ 1.8012 ] Updating boot device parameters
[ 1.8031 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 1.8045 ] Warning: No sdram params
[ 1.8047 ]
[ 1.8047 ] Updating bl info
[ 1.8065 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.8094 ]
[ 1.8095 ] Updating secondary storage information into bct
[ 1.8110 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 1.8130 ]
[ 1.8130 ] Updating Odmdata
[ 1.8147 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 1.8164 ] Warning: No sdram params
[ 1.8167 ]
[ 1.8167 ] Get Signed section of bct
[ 1.8182 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 1.8201 ]
[ 1.8201 ] Signing BCT
[ 1.8235 ] tegrasign --key /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem --list bct_list.xml --pubkeyhash pub_key.key
[ 1.8250 ] PKC key in Open SSL format
[ 1.8253 ] Key size is 256 bytes
[ 1.8255 ] Saving public key in pub_key.key
[ 1.9354 ] Saving public key Hash as binary: pub_key.hash
[ 1.9354 ] Saving public key Hash as big-endian text: pub_key.hash_txt
[ 1.9354 ] Saving public key Hash as little-endian(sysfs) text: pub_key.hash_sysfs_txt
[ 1.9355 ]
[ 1.9355 ] Updating BCT with signature
[ 1.9374 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key
[ 1.9396 ]
[ 1.9397 ] Copying signatures
[ 1.9413 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml --pubkeyhash pub_key.key
[ 1.9535 ]
[ 1.9536 ] Updating BFS information on BCT
[ 1.9550 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin --pubkeyhash pub_key.key
[ 1.9563 ] BFS:
[ 1.9578 ] 0: [PT ] flash.xml.bin (size=4319/131072)
[ 1.9585 ] 1: [TBC] nvtboot_cpu.bin.signed (size=65760/196608)
[ 1.9592 ] 2: [RP1] tegra210-p3448-0000-p3449-0000-a00.dtb.signed (size=215392/1048576)
[ 1.9603 ] 3: [EBT] cboot.bin.signed (size=484304/655360)
[ 1.9610 ] 4: [WB0] warmboot.bin.signed (size=3952/131072)
[ 1.9617 ] 5: [BPF] sc7entry-firmware.bin.signed (size=3376/262144)
[ 1.9625 ] BFS0: 131072 @ 2560 SUM 080edbe7 over 2883584 bytes
[ 1.9632 ] BFS:
[ 1.9633 ] 0: [PT-1] flash.xml.bin (size=4319/131072)
[ 1.9639 ] 1: [TBC-1] nvtboot_cpu.bin.signed (size=65760/196608)
[ 1.9647 ] 2: [RP1-1] tegra210-p3448-0000-p3449-0000-a00.dtb.signed (size=215392/1048576)
[ 1.9657 ] 3: [EBT-1] cboot.bin.signed (size=484304/655360)
[ 1.9665 ] 4: [WB0-1] warmboot.bin.signed (size=3952/131072)
[ 1.9672 ] 5: [BPF-1] sc7entry-firmware.bin.signed (size=3376/262144)
[ 1.9680 ] BFS1: 131072 @ 8704 SUM 080edbe7 over 2883584 bytes
[ 1.9687 ] KFS:
[ 2.0028 ] 0: [DTB] tegra210-p3448-0000-p3449-0000-a00.dtb.signed (size=215392/1048576)
[ 2.0038 ] 1: [TOS] tos-mon-only.img.signed (size=54448/6291456)
[ 2.0046 ] 2: [EKS] eks.img (size=1028/81920)
[ 2.0051 ] 3: [LNX] boot.img.signed (size=483328/67092480)
[ 2.0058 ] KFS0: 1048576 @ 29376546 SUM e6e0a216 over 7905280 bytes
[ 2.0089 ] KFS:
[ 2.0464 ] 0: [DTB-1] tegra210-p3448-0000-p3449-0000-a00.dtb.signed (size=215392/1048576)
[ 2.0475 ] 1: [TOS-1] tos-mon-only.img.signed (size=54448/6291456)
[ 2.0483 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 2.0490 ] 3: [LNX-1] boot.img.signed (size=483328/67092480)
[ 2.0502 ] KFS1: 1048576 @ 29522082 SUM e6e0a216 over 7905280 bytes
[ 2.0524 ]
[ 2.0525 ] Copying signed file in /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/signed
./tegraflash.py --bl cboot.bin.signed --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a00.dtb.signed --applet rcm_1_signed.rcm --cmd "secureflash;reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a00.dtb" --key "/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem"
saving flash command in /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/flash_win.bat
*** no-flash flag enabled. Exiting now... ***
| Step 2: Extract Signed Binaries
copying cboot.bin.signed ... succeeded.
copying P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct ... succeeded.
copying tegra210-p3448-0000-p3449-0000-a00.dtb.signed ... succeeded.
copying rcm_1_signed.rcm ... succeeded.
copying flash.xml ... succeeded.
copying flash.xml.bin ... succeeded.
Also, whenever I execute the nvmassflashgen.sh, it fails for the first time as follow. But it succeded at the next excution (without plugging off).
./tegraflash.py --chip 0x21 --applet "/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin" --key "/home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem"
version 1.0.0
[ 0.0036 ] Generating RCM messages
[ 0.0053 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0070 ] RCM 0 is saved as rcm_0.rcm
[ 0.0080 ] RCM 1 is saved as rcm_1.rcm
[ 0.0080 ] List of rcm files are saved in rcm_list.xml
[ 0.0080 ]
[ 0.0081 ] Signing RCM messages
[ 0.0097 ] tegrasign --key /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/emi_pkc.pem --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0114 ] PKC key in Open SSL format
[ 0.0119 ] Key size is 256 bytes
[ 0.0122 ] Saving public key in pub_key.key
[ 0.2238 ] Saving public key Hash as binary: pub_key.hash
[ 0.2238 ] Saving public key Hash as big-endian text: pub_key.hash_txt
[ 0.2238 ] Saving public key Hash as little-endian(sysfs) text: pub_key.hash_sysfs_txt
[ 0.2238 ]
[ 0.2239 ] Copying signature to RCM mesages
[ 0.2259 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[ 0.2286 ]
[ 0.2287 ] Boot Rom communication
[ 0.2306 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.2325 ] RCM version 0X4
[ 0.5980 ] Boot Rom communication failed
[ 0.5981 ]
Error: Return value 3
Command tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
Reading board information failed.
*** ERROR: flashcmd.txt generation failed.
For the error
Please add
BOARDID=3448 FAB=200 BOARDSKU=0002
in the command line.
Also have you tried the command without -r? Don’t see the option listed in README_Massflash.txt
Oh, I see. I need those parameters again.
I have tried and found the command finished successfully.
$ sudo ./nvmassflashgen.sh BOARDID=3448 FAB=200 BOARDSKU=0002 -x 0x21 -y PKC -u ../emi_pkc.pem -r jetson-nano-emmc mmcblk0p1
Making system.img...
populating rootfs from /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 6291456( 6 blks) ==> 28:6291468
1: SKP: 31457280( 30 blks) ==> 6291496:12
2: RAW: 2097152( 2 blks) ==> 6291508:2097164
3: SKP: 94371840( 90 blks) ==> 8388672:12
4: RAW: 1048576( 1 blks) ==> 8388684:1048588
5: SKP: 3145728( 3 blks) ==> 9437272:12
6: RAW: 44040192( 42 blks) ==> 9437284:44040204
7: SKP: 1048576( 1 blks) ==> 53477488:12
8: RAW: 220200960( 210 blks) ==> 53477500:220200972
9: SKP: 3145728( 3 blks) ==> 273678472:12
10: RAW: 80740352( 77 blks) ==> 273678484:80740364
11: SKP: 15728640( 15 blks) ==> 354418848:12
12: RAW: 168820736( 161 blks) ==> 354418860:168820748
13: SKP: 3145728( 3 blks) ==> 523239608:12
14: RAW: 265289728( 253 blks) ==> 523239620:265289740
15: SKP: 3145728( 3 blks) ==> 788529360:12
16: RAW: 265289728( 253 blks) ==> 788529372:265289740
17: SKP: 3145728( 3 blks) ==> 1053819112:12
18: RAW: 842006528( 803 blks) ==> 1053819124:842006540
19: SKP: 1048576( 1 blks) ==> 1895825664:12
20: RAW: 95420416( 91 blks) ==> 1895825676:95420428
21: SKP: 30408704( 29 blks) ==> 1991246104:12
22: RAW: 32505856( 31 blks) ==> 1991246116:32505868
23: SKP: 34603008( 33 blks) ==> 2023751984:12
24: RAW: 17825792( 17 blks) ==> 2023751996:17825804
25: SKP: 15728640( 15 blks) ==> 2041577800:12
26: RAW: 1074790400( 1025 blks) ==> 2041577812:1074790412
27: SKP: 3145728( 3 blks) ==> 3116368224:12
28: RAW: 265289728( 253 blks) ==> 3116368236:265289740
29: SKP: 3145728( 3 blks) ==> 3381657976:12
30: RAW: 67108864( 64 blks) ==> 3381657988:67108876
31: SKP: 4194304( 4 blks) ==> 3448766864:12
32: RAW: 105906176( 101 blks) ==> 3448766876:105906188
33: SKP: 3145728( 3 blks) ==> 3554673064:12
34: RAW: 36700160( 35 blks) ==> 3554673076:36700172
35: SKP: 1048576( 1 blks) ==> 3591373248:12
36: RAW: 35651584( 34 blks) ==> 3591373260:35651596
37: SKP: 2097152( 2 blks) ==> 3627024856:12
38: RAW: 15728640( 15 blks) ==> 3627024868:15728652
39: SKP: 1048576( 1 blks) ==> 3642753520:12
40: RAW: 32505856( 31 blks) ==> 3642753532:32505868
41: SKP: 1048576( 1 blks) ==> 3675259400:12
42: RAW: 33554432( 32 blks) ==> 3675259412:33554444
43: SKP: 1048576( 1 blks) ==> 3708813856:12
44: RAW: 27262976( 26 blks) ==> 3708813868:27262988
45: SKP: 5242880( 5 blks) ==> 3736076856:12
46: RAW: 119537664( 114 blks) ==> 3736076868:119537676
47: SKP: 6291456( 6 blks) ==> 3855614544:12
48: RAW: 54525952( 52 blks) ==> 3855614556:54525964
49: SKP: 4194304( 4 blks) ==> 3910140520:12
50: RAW: 40894464( 39 blks) ==> 3910140532:40894476
51: SKP: 1048576( 1 blks) ==> 3951035008:12
52: RAW: 24117248( 23 blks) ==> 3951035020:24117260
53: SKP: 1048576( 1 blks) ==> 3975152280:12
54: RAW: 49283072( 47 blks) ==> 3975152292:49283084
55: SKP: 26214400( 25 blks) ==> 4024435376:12
56: RAW: 16777216( 16 blks) ==> 4024435388:16777228
57: SKP: 83886080( 80 blks) ==> 4041212616:12
58: RAW: 1222639616( 1166 blks) ==> 4041212628:1222639628
59: SKP: 1048576( 1 blks) ==> 5263852256:12
60: RAW: 65011712( 62 blks) ==> 5263852268:65011724
61: SKP: 3145728( 3 blks) ==> 5328863992:12
62: RAW: 668991488( 638 blks) ==> 5328864004:668991500
63: SKP: 2097152( 2 blks) ==> 5997855504:12
64: RAW: 61865984( 59 blks) ==> 5997855516:61865996
65: SKP: 22020096( 21 blks) ==> 6059721512:12
66: RAW: 28311552( 27 blks) ==> 6059721524:28311564
67: SKP: 72351744( 69 blks) ==> 6088033088:12
68: RAW: 1048576( 1 blks) ==> 6088033100:1048588
69: SKP: 3145728( 3 blks) ==> 6089081688:12
70: RAW: 74448896( 71 blks) ==> 6089081700:74448908
71: SKP: 5242880( 5 blks) ==> 6163530608:12
72: RAW: 1157627904( 1104 blks) ==> 6163530620:1157627916
73: SKP: 33554432( 32 blks) ==> 7321158536:12
74: RAW: 11534336( 11 blks) ==> 7321158548:11534348
75: SKP: 5242880( 5 blks) ==> 7332692896:12
76: RAW: 200278016( 191 blks) ==> 7332692908:200278028
77: SKP: 1048576( 1 blks) ==> 7532970936:12
78: RAW: 57671680( 55 blks) ==> 7532970948:57671692
79: SKP: 1048576( 1 blks) ==> 7590642640:12
80: RAW: 36700160( 35 blks) ==> 7590642652:36700172
81: SKP: 5242880( 5 blks) ==> 7627342824:12
82: RAW: 57671680( 55 blks) ==> 7627342836:57671692
83: SKP: 1048576( 1 blks) ==> 7685014528:12
84: RAW: 128974848( 123 blks) ==> 7685014540:128974860
85: SKP: 5242880( 5 blks) ==> 7813989400:12
86: RAW: 183500800( 175 blks) ==> 7813989412:183500812
87: SKP: 1048576( 1 blks) ==> 7997490224:12
88: RAW: 49283072( 47 blks) ==> 7997490236:49283084
89: SKP: 26214400( 25 blks) ==> 8046773320:12
90: RAW: 14680064( 14 blks) ==> 8046773332:14680076
91: SKP: 85983232( 82 blks) ==> 8061453408:12
92: RAW: 417333248( 398 blks) ==> 8061453420:417333260
93: SKP: 2097152( 2 blks) ==> 8478786680:12
94: RAW: 88080384( 84 blks) ==> 8478786692:88080396
95: SKP: 4194304( 4 blks) ==> 8566867088:12
96: RAW: 96468992( 92 blks) ==> 8566867100:96469004
97: SKP: 4194304( 4 blks) ==> 8663336104:12
98: RAW: 23068672( 22 blks) ==> 8663336116:23068684
99: SKP: 2097152( 2 blks) ==> 8686404800:12
100: RAW: 108003328( 103 blks) ==> 8686404812:108003340
101: SKP: 1048576( 1 blks) ==> 8794408152:12
102: RAW: 74448896( 71 blks) ==> 8794408164:74448908
103: SKP: 1048576( 1 blks) ==> 8868857072:12
104: RAW: 255852544( 244 blks) ==> 8868857084:255852556
105: SKP: 4194304( 4 blks) ==> 9124709640:12
106: RAW: 99614720( 95 blks) ==> 9124709652:99614732
107: SKP: 1048576( 1 blks) ==> 9224324384:12
108: RAW: 40894464( 39 blks) ==> 9224324396:40894476
109: SKP: 1048576( 1 blks) ==> 9265218872:12
110: RAW: 103809024( 99 blks) ==> 9265218884:103809036
111: SKP: 5242880( 5 blks) ==> 9369027920:12
112: RAW: 22020096( 21 blks) ==> 9369027932:22020108
113: SKP: 3145728( 3 blks) ==> 9391048040:12
114: RAW: 89128960( 85 blks) ==> 9391048052:89128972
115: SKP: 565182464( 539 blks) ==> 9480177024:12
116: RAW: 9437184( 9 blks) ==> 9480177036:9437196
117: SKP: 24117248( 23 blks) ==> 9489614232:12
118: RAW: 18874368( 18 blks) ==> 9489614244:18874380
119: SKP: 81788928( 78 blks) ==> 9508488624:12
120: RAW: 1048576( 1 blks) ==> 9508488636:1048588
121: SKP: 3145728( 3 blks) ==> 9509537224:12
122: RAW: 339738624( 324 blks) ==> 9509537236:339738636
123: SKP: 1048576( 1 blks) ==> 9849275872:12
124: RAW: 546308096( 521 blks) ==> 9849275884:546308108
125: SKP: 1121976320( 1070 blks) ==> 10395583992:12
126: RAW: 11534336( 11 blks) ==> 10395584004:11534348
127: SKP: 1048576( 1 blks) ==> 10407118352:12
128: RAW: 1048576( 1 blks) ==> 10407118364:1048588
129: SKP: 19922944( 19 blks) ==> 10408166952:12
130: RAW: 23068672( 22 blks) ==> 10408166964:23068684
131: SKP: 77594624( 74 blks) ==> 10431235648:12
132: RAW: 1331691520( 1270 blks) ==> 10431235660:1331691532
133: SKP: 10485760( 10 blks) ==> 11762927192:12
134: RAW: 7340032( 7 blks) ==> 11762927204:7340044
135: SKP: 663748608( 633 blks) ==> 11770267248:12
-- Total: ---------------------------------------------------
136 CHUNK 15032385536( 14336 blks) ==> 11770267260(11225 blks)
done.
system.img built successfully.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a00.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a00.dtb"
| Step 2: Sign Binaries
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a00.dtb --applet nvtboot_recovery.bin --cmd " sign" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a00.dtb" --keep --skipuid
version 1.0.0
[ 0.4082 ] tegrasign --key None --getmode mode.txt
[ 0.4099 ] Assuming zero filled SBK key
[ 0.4101 ]
[ 0.4684 ] Generating RCM messages
[ 0.4703 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.4723 ] RCM 0 is saved as rcm_0.rcm
[ 0.4732 ] RCM 1 is saved as rcm_1.rcm
[ 0.4735 ] List of rcm files are saved in rcm_list.xml
[ 0.4735 ]
[ 0.4736 ] Signing RCM messages
[ 0.4755 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.4774 ] Assuming zero filled SBK key
[ 0.4881 ]
[ 0.4881 ] Copying signature to RCM mesages
[ 0.4901 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.5374 ]
[ 0.5374 ] Parsing partition layout
[ 0.7585 ] tegraparser --pt flash.xml.tmp
[ 1.0729 ]
[ 1.0730 ] Creating list of images to be signed
[ 1.2839 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 2.0567 ]
[ 2.0567 ] Generating signatures
[ 2.0587 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.0606 ] Assuming zero filled SBK key
[ 2.7748 ]
[ 2.7748 ] Generating br-bct
[ 3.2368 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 3.2387 ] Copying Sdram info from 0 to 1 set
[ 3.4316 ] Copying Sdram info from 1 to 2 set
[ 3.4316 ] Copying Sdram info from 2 to 3 set
[ 3.4316 ]
[ 3.4316 ] Updating boot device parameters
[ 3.4332 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 3.4352 ] Warning: No sdram params
[ 3.5134 ]
[ 3.5134 ] Updating bl info
[ 3.5153 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.6186 ]
[ 3.6187 ] Updating secondary storage information into bct
[ 3.6206 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 3.7097 ]
[ 3.7098 ] Updating Odmdata
[ 3.7117 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 3.7136 ] Warning: No sdram params
[ 3.8167 ]
[ 3.8168 ] Get Signed section of bct
[ 3.8187 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 3.8208 ]
[ 3.8208 ] Signing BCT
[ 3.8247 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 3.8266 ] Assuming zero filled SBK key
[ 3.8276 ]
[ 3.8277 ] Updating BCT with signature
[ 3.8296 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 4.0075 ]
[ 4.0076 ] Copying signatures
[ 4.0096 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 4.4488 ]
[ 4.4489 ] Updating BFS information on BCT
[ 4.4509 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 4.4528 ] BFS:
[ 4.4560 ] 0: [PT ] flash.xml.bin (size=4337/131072)
[ 4.4566 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 4.4572 ] 2: [RP1] tegra210-p3448-0000-p3449-0000-a00.dtb.encrypt (size=215392/1048576)
[ 4.4582 ] 3: [EBT] cboot.bin.encrypt (size=484304/655360)
[ 4.4588 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 4.4594 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 4.4602 ] BFS0: 131072 @ 2560 SUM 49803955 over 2883584 bytes
[ 4.4608 ] BFS:
[ 4.4614 ] 0: [PT-1] flash.xml.bin (size=4337/131072)
[ 4.4617 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 4.4620 ] 2: [RP1-1] tegra210-p3448-0000-p3449-0000-a00.dtb.encrypt (size=215392/1048576)
[ 4.4625 ] 3: [EBT-1] cboot.bin.encrypt (size=484304/655360)
[ 4.4628 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 4.4631 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 4.4635 ] BFS1: 131072 @ 8704 SUM 49803955 over 2883584 bytes
[ 4.4638 ] KFS:
[ 4.5074 ] 0: [DTB] tegra210-p3448-0000-p3449-0000-a00.dtb.encrypt (size=215392/1048576)
[ 4.5084 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 4.5091 ] 2: [EKS] eks.img (size=1028/81920)
[ 4.5095 ] 3: [LNX] boot.img.encrypt (size=483328/67092480)
[ 4.5101 ] KFS0: 1048576 @ 29376546 SUM 23c068dd over 7905280 bytes
[ 4.5125 ] KFS:
[ 4.5512 ] 0: [DTB-1] tegra210-p3448-0000-p3449-0000-a00.dtb.encrypt (size=215392/1048576)
[ 4.5522 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 4.5529 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 4.5534 ] 3: [LNX-1] boot.img.encrypt (size=483328/67092480)
[ 4.5540 ] KFS1: 1048576 @ 29522082 SUM 23c068dd over 7905280 bytes
[ 4.5977 ]
[ 4.5978 ] Copying signed file in /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/signed
Keep temporary directory /home/tsato/Desktop/l4timages/Nano/L4T32.3.1/Linux_for_Tegra/bootloader/4819
| Step 3: Generate Mass-flash scripts
| Step 4: Generate Mass-flash image tarball
copying nvmflash.sh ... succeeded.
copying nvaflash.sh ... succeeded.
copying emmc_bootblob_ver.txt ... succeeded.
mfi_jetson-nano-emmc/
mfi_jetson-nano-emmc/mkbctpart
mfi_jetson-nano-emmc/tos-mon-only.img
mfi_jetson-nano-emmc/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct.encrypt
mfi_jetson-nano-emmc/boot.img.signed
mfi_jetson-nano-emmc/images_list.xml
mfi_jetson-nano-emmc/flash.xml.bin
mfi_jetson-nano-emmc/nvtboot.bin.signed
mfi_jetson-nano-emmc/sc7entry-firmware.bin
mfi_jetson-nano-emmc/nvtboot_recovery.bin
mfi_jetson-nano-emmc/tegra210-p3448-0000-p3449-0000-a00.dtb
mfi_jetson-nano-emmc/cboot.bin.encrypt
mfi_jetson-nano-emmc/tos-mon-only.img.signed
mfi_jetson-nano-emmc/rcm_1.rcm
mfi_jetson-nano-emmc/LICENSE.mkgpt
mfi_jetson-nano-emmc/tegrarcm
mfi_jetson-nano-emmc/cvm.bin
mfi_jetson-nano-emmc/tos.img
mfi_jetson-nano-emmc/mkgpt
mfi_jetson-nano-emmc/mkbootimg
mfi_jetson-nano-emmc/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg
mfi_jetson-nano-emmc/nvtboot.bin.encrypt
mfi_jetson-nano-emmc/tegrabct
mfi_jetson-nano-emmc/rcm_1_signed.rcm
mfi_jetson-nano-emmc/rp4.blob
mfi_jetson-nano-emmc/rcm_list_signed.xml
mfi_jetson-nano-emmc/l4t_initrd.img
mfi_jetson-nano-emmc/odmfuse_pkc.xml
mfi_jetson-nano-emmc/eks.img
mfi_jetson-nano-emmc/warmboot.bin.signed
mfi_jetson-nano-emmc/nvaflash.sh
mfi_jetson-nano-emmc/cboot.bin.signed
mfi_jetson-nano-emmc/tegrahost
mfi_jetson-nano-emmc/warmboot.bin.encrypt
mfi_jetson-nano-emmc/tegra210-p3448-0000-p3449-0000-a00.dtb.encrypt
mfi_jetson-nano-emmc/rcm_list.xml
mfi_jetson-nano-emmc/tegraflash_internal.py
mfi_jetson-nano-emmc/NVIDIA_Trademark_License_Addendum_SW.pdf
mfi_jetson-nano-emmc/chkbdinfo
mfi_jetson-nano-emmc/tegraparser
mfi_jetson-nano-emmc/nvidia-l4t-bootloader_32.3.1-20191209225816_arm64.deb
mfi_jetson-nano-emmc/tegradevflash
mfi_jetson-nano-emmc/tegraflash.py
mfi_jetson-nano-emmc/LICENSE.tos-mon-only.img.arm-trusted-firmware
mfi_jetson-nano-emmc/LICENSE.mkbootimg
mfi_jetson-nano-emmc/nvmflash.sh
mfi_jetson-nano-emmc/nvtboot_cpu.bin.encrypt
mfi_jetson-nano-emmc/bmp.blob
mfi_jetson-nano-emmc/mksparse
mfi_jetson-nano-emmc/nv_boot_control.conf
mfi_jetson-nano-emmc/badpage.bin
mfi_jetson-nano-emmc/nvtboot_cpu.bin.signed
mfi_jetson-nano-emmc/sc7entry-firmware.bin.signed
mfi_jetson-nano-emmc/LICENSE.mkbctpart
mfi_jetson-nano-emmc/tegra210-p3448-0000-p3449-0000-a00.dtb.signed
mfi_jetson-nano-emmc/sc7entry-firmware.bin.encrypt
mfi_jetson-nano-emmc/extlinux.conf
mfi_jetson-nano-emmc/tegrasign
mfi_jetson-nano-emmc/rcm_0_signed.rcm
mfi_jetson-nano-emmc/LICENSE.mksparse
mfi_jetson-nano-emmc/system.img
mfi_jetson-nano-emmc/bct_list_signed.xml
mfi_jetson-nano-emmc/LICENSE.chkbdinfo
mfi_jetson-nano-emmc/bct_list.xml
mfi_jetson-nano-emmc/tegra210-p3448-0002-p3449-0000-b00.dtb
mfi_jetson-nano-emmc/flash_win.bat
mfi_jetson-nano-emmc/emmc_bootblob_ver.txt
mfi_jetson-nano-emmc/rcm_0.rcm
mfi_jetson-nano-emmc/LICENSE.u-boot
mfi_jetson-nano-emmc/rcm_0_encrypt.rcm
mfi_jetson-nano-emmc/rcm_1_encrypt.rcm
mfi_jetson-nano-emmc/tegraflash_internal.pyc
mfi_jetson-nano-emmc/nvtboot_recovery_cpu.bin
mfi_jetson-nano-emmc/boot.img.encrypt
mfi_jetson-nano-emmc/images_list_signed.xml
mfi_jetson-nano-emmc/tos-mon-only.img.encrypt
mfi_jetson-nano-emmc/initrd
mfi_jetson-nano-emmc/BUP_generator.py
*** Mass Flashing tarball mfi_jetson-nano-emmc.tbz2 is ready.
1. Download mfi_jetson-nano-emmc.tbz2 to each flashing hosts.
2. Untar mfi_jetson-nano-emmc.tbz2. ( tar xvjf mfi_jetson-nano-emmc.tbz2 )
3. cd mfi_jetson-nano-emmc
4. Connect Jetson boards(jetson-nano-emmc only) and put them in RCM mode.
5. ./nvmflash.sh
Then, we can flash this image in batches.
But again, system.img was rebuilt, and with which our own pre-built one was replaced.
So, how are we supposed to flash our own image? Is there any way to achieve this without -r option? Perhaps, extract the mfi tarball file, replace the system.img with our own image, and compress again?
Please find the line in nvmassflashgen.sh
BOARDID=${BOARDID} BOARDSKU=${BOARDSKU} FAB=${FAB} FUSELEVEL=${FUSELEVEL} ${curdir}/flash.sh --no-flash $@
And add -r
