How to freely change the memory frequency on Jetson TX2 NX
I followed the instructions in the official document to change the memory frequency, but found that it could only be manually adjusted to the maximum or minimum frequency. When I tried to adjust it to a middle frequency, it did not respond. I would like to know how to solve this problem.
My jetpack version is 4.6.6,and the method for documentation is as follows:
There are only some fixed values of frequency that could be adjusted. This is not something that can be changed to any arbitrary value.
Yes, I am aware of this situation, but even with the frequency shown in the figure below, I still cannot complete it.
image792×220 4.84 KB
what do you have under /sys/kernel/debug/bpmp/debug/clk/emc?
What value did you set and fail?
such as 408M and 1331.2M
