Our sensor output 1920*1080 Raw10 image, line length is 2400.
I config the driver in dtsi like this:
mode0 {
mclk_khz = “25000”;
num_lanes = “4”;
tegra_sinterface = “serial_g”;
vc_id = “1”;
phy_mode = “DPHY”;
discontinuous_clk = “yes”;
dpcm_enable = “false”;
cil_settletime = “0”;
mode_type = “bayer”;
csi_pixel_bit_depth = “10”;
pixel_phase = “rggb”;
active_w = "1920";
active_h = "1080";
readout_orientation = "0";
line_length = "3000";
inherent_gain = "1";
mclk_multiplier = "12.8";
pix_clk_hz = "320000000";
min_gain_val = "1.0";
max_gain_val = "177";
gain_step_pitch = "0.1";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "60";
min_exp_time = "16.165";
max_exp_time = "165770";
exp_time_1h = "8";
embedded_metadata_height = "0";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
liub960_ub960_out7: endpoint {
vc-id = <1>;
port-index = <6>;
bus-width = <4>;
remote-endpoint = <&liub960_csi_in7>;
I use this cmd to get image by v4l2:
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video0
But I cannot get image, and I find there are errors in rcpu log. There is a CHANSEL_NOMATCH(0x569) and a CHANSEL_FAULT(0x100). The CHANSEL_FAULT(0x100) means “PIXEL_LONG_LINE”. What shall I do to fix this error?
When the sensor output 1280768 raw10 image, and I change the resolution to 1280768 and line length to 1600, it’s OK.
kworker/1:3-2094 [001] .... 321.752060: rtcpu_vinotify_event: tstamp:10241715458 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9890363648 data:0x10000000
kworker/1:3-2094 [001] .... 321.752061: rtcpu_vinotify_event: tstamp:10241715589 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9890367488 data:0x31000001
kworker/1:3-2094 [001] .... 321.752062: rtcpu_vinotify_event: tstamp:10241715751 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9890368480 data:0x07020001
kworker/1:3-2094 [001] .... 321.752063: rtcpu_vinotify_event: tstamp:10241715876 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9890404960 data:0x10000000
kworker/1:3-2094 [001] .... 321.752083: rtcpu_vinotify_event: tstamp:10241716017 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9890408864 data:0x31000002
kworker/1:3-2094 [001] .... 321.752084: rtcpu_vinotify_event: tstamp:10241716143 tag:FS channel:0x01 frame:0 vi_tstamp:10241641252 data:0x00000010
kworker/1:3-2094 [001] .... 321.752085: rtcpu_vinotify_event: tstamp:10241716284 tag:FS channel:0x00 frame:0 vi_tstamp:10241641306 data:0x00000010
kworker/1:3-2094 [001] .... 321.752086: rtcpu_vinotify_event: tstamp:10241716411 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:10241641309 data:0x00000000
kworker/1:3-2094 [001] .... 321.752086: rtcpu_vinotify_event: tstamp:10241716553 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:10241641461 data:0x00000569
kworker/1:3-2094 [001] .... 321.752087: rtcpu_vinotify_event: tstamp:10241716677 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:10241641672 data:0x00000001
kworker/1:3-2094 [001] .... 321.752088: rtcpu_vinotify_event: tstamp:10241716839 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9904966304 data:0x08020001
kworker/1:3-2094 [001] .... 321.752089: rtcpu_vinotify_event: tstamp:10241716961 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:10241641796 data:0x00000100
kworker/1:3-2094 [001] .... 321.752089: rtcpu_vinotify_event: tstamp:10241717162 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9904992736 data:0x01020001
kworker/1:3-2094 [001] .... 321.752090: rtcpu_vinotify_event: tstamp:10242257460 tag:FE channel:0x01 frame:0 vi_tstamp:10242069359 data:0x00000020
kworker/1:3-2094 [001] .... 321.808112: rtcpu_vinotify_error: tstamp:10243210785 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:10243203258 data:0x000000a0
kworker/1:3-2094 [001] .... 321.808115: rtcpu_vinotify_error: tstamp:10243211602 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:10243203420 data:0x00000569
kworker/1:3-2094 [001] .... 321.808116: rtcpu_vinotify_event: tstamp:10243212016 tag:FS channel:0x01 frame:0 vi_tstamp:10243203206 data:0x00000010
kworker/1:3-2094 [001] .... 321.808117: rtcpu_vinotify_event: tstamp:10243212140 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:10243203258 data:0x000000a0
kworker/1:3-2094 [001] .... 321.808119: rtos_queue_send_from_isr_failed: tstamp:10243220567 queue:0x0bcb41f8
kworker/1:3-2094 [001] .... 321.808120: rtos_queue_send_from_isr_failed: tstamp:10243220720 queue:0x0bcb8a60
kworker/1:3-2094 [001] .... 321.808121: rtos_queue_send_from_isr_failed: tstamp:10243220860 queue:0x0bcba5e0
kworker/1:3-2094 [001] .... 321.808139: rtos_queue_send_from_isr_failed: tstamp:10243220994 queue:0x0bcbb3a0
kworker/1:3-2094 [001] .... 321.808140: rtos_queue_send_from_isr_failed: tstamp:10243221126 queue:0x0bcbc160
kworker/1:3-2094 [001] .... 321.808141: rtcpu_vinotify_event: tstamp:10243695466 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:10243203259 data:0x01000000
kworker/1:3-2094 [001] .... 321.808142: rtcpu_vinotify_event: tstamp:10243695596 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9954953664 data:0x01020001
kworker/1:3-2094 [001] .... 321.808143: rtcpu_vinotify_event: tstamp:10243695759 tag:FS channel:0x00 frame:0 vi_tstamp:10243203259 data:0x00000010
kworker/1:3-2094 [001] .... 321.808143: rtcpu_vinotify_event: tstamp:10243695908 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:10243203262 data:0x00000000
kworker/1:3-2094 [001] .... 321.808144: rtcpu_vinotify_event: tstamp:10243696069 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9954970592 data:0x07020002
kworker/1:3-2094 [001] .... 321.808145: rtcpu_vinotify_event: tstamp:10243696197 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:10243203262 data:0x00000000
kworker/1:3-2094 [001] .... 321.808146: rtcpu_vinotify_event: tstamp:10243696356 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:10243203420 data:0x00000569
kworker/1:3-2094 [001] .... 321.808147: rtcpu_vinotify_event: tstamp:10243696480 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:10243203631 data:0x00000001
