How to import a NumPy occupancy map into Isaac Sim?
Hi everyone,
I’m working on a project using Isaac Sim and I have a 2D NumPy array representing an occupancy map (0 = free, 1 = occupied). I would like to import this map into Isaac Sim.
Specifically, I’m wondering:
  1. What’s the best way to convert a NumPy occupancy grid into a usable map inside Isaac Sim?
Any code snippets, extensions, or tools that can help would be greatly appreciated!
Thanks in advance!
Hi @inamsajjad9688! You can try to convert your NumPy occupancy map into an image format (e.g. png) and a yaml file which includes map metadata (cell size, origin, etc.). Isaac Sim would work with this format. Here is a tutorial of how Isaac Sim generates an occupancy map: Mapping — Isaac Sim Documentation. You can refer this tutorial to understand what data and format Isaac Sim uses.
I am not sure how you would use the map in Isaac Sim, but here is a tutorial of using block world generator with a map image: Mapping — Isaac Sim Documentation.
Thank you zhengwang.
Is there a python code for this as well?
Do you mean converting from numpy occupancy map to an image? I found an example on GeeksforGeeks Convert a NumPy array to an image - GeeksforGeeks
Hello!
Best regards,
