So I am trying to flash a Jetson Orin remotely and set the user/IP address before flashing. To do this I am planning on having a raspberry pi (or another edge device) connected to the jetson through the USB and having linux tegra set up with the correct ip and user. Is this possible with how the flashing software is setup? I saw somewhere that aarch64 architecture wasn’t supported but has that since changed?
Thanks for visiting the NVIDIA Developer forums. Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
It is not supported. For flashing Jetson platforms, please use x86 host PC in Ubuntu OS.
Do you have a recommendation for an x86 edge devices that we could use for this?
