I packaged all the deb packages and installed them through the mlnx_add_kernel_support.sh script, but I don’t know which ko files are necessary for the device.
At the same time, I should create which devices to the /dev directory, and also provide technical assistance.
mlnxofedinstall script should do all the work and it will prompt to run kernel support if necessary by running mlnx_add_kernel_support. However, be sure that your OS is in the listed as supported in Mellanox OFED release notes.
Once Mellanox OFED installed properly it will load the driver automatically.
mlx4_en & mlx4_ib - are the drivers for ConnectX-2 and ConnectX-3 devices
mlx5_ib - for ConnectX-4 and newer devices.
There are other dependencies, but when you do ‘modprobe mlx4_ib’ kernel will resolve them automatically. If you gonna load drivers manually, you might need to load another module one explicitly - ib_uverbs. But as I said, if Mellanox OFED installed in the right way, nothing need to be done manually.
Were you ever able to get Mellanox OFED working in CoreOS. I don’t see CoreOS listed in the supported operating systems within OFED, but I am curious if there is a workaround.
